- 13 Aug 2004
- England
I'm attempting to fix the curtain rail, the problem has been that the screws and rawl plug are quite shallow and the surrounding plaster has worn away so it's started to sag.
I attempted to drill further in with masonry bits (carbide) but the drill wouldn't go in any further, I tried another hole a couple of inches above and still it wouldn't go any further than about an inch.
What could I be hitting that is causing this?
It's a pain in the ass if you later decide to paper the wall. It looks old fashioned too in my opinion.
