Problem I really need help with
17 Feb 2014
I am using a Radeon hd 7870 GPU.
For a LG 1440x3440 21:9 display.
My GPU only supports HDMI or DVI so I can only get 50hertz for now.
My issue though is flickering, whenever windows are dragged, or any movement on screen will cause flashing and flickering.
However, when I plug in a second display (1080, 24"). It fixes everything, and my 1440 display runs flawlessly. Which is odd.
Now I no longer have a second display and cannot figure out how to fix this.
Does anyone know what might have changed when a second monitor is being used?
Any help at all would great.
Or even some help on how to search for help?
I'm trying to be specific, but searching leads to things that aren't helpful.
I would imagine that the 2d clocks aren't able to drive that resolution and that a second monitor forces the clocks higher. Try using afterburner to force higher 2d clocks and see if that helps.
Just enabled a VGA out, screen went black, and popped back perfectly.
I guess I'll have to live a tiny gap on the screen where the mouse might get lost; But at least the screen is back to normal. So thank you!
And I will try and force the clocks up.
I tried moving speeds around with the AMD catalyst control centre. But that never seemed to work.
