Problem in XP
21 Sep 2006
I am having a little problem with Windows XP. As I use my computer in windows I experience a slow but steady decrease in the amount of applications I can open at any one time. This is most noticeable in Internet explorer where the amount of windows or tabs I am able to open steadily decreases, but affects other programs as well.
My system is below.
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB)
BFG GeForce 8800 GTS OC 640MB GDDR3 HDTV/Dual DVI (PCI-Express)
Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775)
Seagate Barracuda 7200.10 200GB ST3200820AS SATA-II 8MB
Western Digital Caviar SE16 500GB 5000AAKS SATA-II 16MB Cache – OEM £16.49 x 1 - Sony DWG120A 16x16 DVD±RW Dual Layer ReWriter (Black)
If anyone can help I would be grateful
Well it dose immediately strike me as two possible things:
1.) Your RAM has an issue be it hardware wise or temps, try running Memtest86 for 36 hours and or run it then start using the PC as normal, and give a feel to your RAM sticks when this is going on a few minuets in.
2.) You have an issue with you install, tried doing a clean install but also throw in the latest BIOS (Careful unless you know what to do) and up to date drivers for all hardware.
