Problem installing 10.5 onto Mac Mini
25 Dec 2002
Ok, decided to do a fresh install of 10.5 onto my Mini, got my install disk (I purchased the family license so it's a copy onto a DVD-DL)
It boots off it, checks the disk, all is good. Then it tries to install, gets to "estimated time 1hour 6 minutes" and sits there for several hours doing nothing.
I've had a look at the logs and it copies a file onto the hard disk and tries to uncompress it and just sits there.
Any advice?
Update: I've just ran the Apple Hardware Test and it's come back with 4MEM/1/40000000 which as far as I can tell means some dodgy memory somewhere? Got two new sticks to test in it and see if that cures it.
Were you on 10.4 and trying to install 10.5? as there is a BIOS update required prior to 10.5?
Check the machine is not overheating - I had that with my MBP when I'd get intermittent memory problems (6hour run no problem with the fans on).
