Problem installing Azureus plugins on Ubuntu
14 Apr 2003
Deepest Yorkshire
I have installed Azureus via synaptic on my Feisty install, and I would like to install 3 plugins:
Speed Scheduler
XML over HTTP
Azureus Web UI
At first I was getting a "No suitable parser" error for the speed scheduler plugin but the webui worked.
Then I installed the Sun Java runtimes and speed scheduler works.
However now when I install the other plugins it crashes Azureus when it loads up the plugins - the gui flashes up on screen then crashes. The only way to repair this is to delete the /home/me/.azureus folder.
The error report when starting Azureus is like so:
Code:
# An unexpected error has been detected by Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0xb46a3172, pid=12339, tid=3084368784
# Java VM: Java HotSpot(TM) Client VM (1.6.0-b105 mixed mode, sharing)
# Problematic frame:
# C  [libglibjni-0.4.so+0x9172]
# If you would like to submit a bug report, please visit:
#   http://java.sun.com/webapps/bugreport/crash.jsp
---------------  T H R E A D  ---------------
Current thread (0x08058c00):  JavaThread "main" [_thread_in_native, id=12342]
siginfo:si_signo=11, si_errno=0, si_code=1, si_addr=0xfa00c044
Registers:
EAX=0xfa00c000, EBX=0xb46a76c4, ECX=0xb4c81748, EDX=0xb5152ac7
ESP=0xb7d7a7c0, EBP=0xb7d7a7e8, ESI=0x083bd8e8, EDI=0x00000004
EIP=0xb46a3172, CR2=0xfa00c044, EFLAGS=0x00010292
Top of Stack: (sp=0xb7d7a7c0)
0xb7d7a7c0:   083bd8e8 b5205654 b7d7ac9c b4eb9f6a
0xb7d7a7d0:   00000004 00000001 b4c81a80 b4c81748
0xb7d7a7e0:   0888d170 00000004 b7d7ac58 b4c23525
0xb7d7a7f0:   b5152ac7 00000010 0888d170 083bd8e8
0xb7d7a800:   b7d7a93c b5111c20 b7d7ac9c b5205654
0xb7d7a810:   b5152ac7 00000000 00000000 00000000
0xb7d7a820:   00000010 00000000 b46a3150 00000005
0xb7d7a830:   00000010 00000001 00000010 b4cbe670
Instructions: (pc=0xb46a3172)
0xb46a3162:   e8 a0 c3 ff ff 81 c3 5d 45 00 00 8b 06 89 34 24
0xb46a3172:   ff 50 44 8b 16 8b 45 10 89 34 24 89 44 24 04 ff
Stack: [0xb7d2b000,0xb7d7c000),  sp=0xb7d7a7c0,  free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [libglib-2.0.so.0+0x36525]  g_logv+0x2e5
C  [libglib-2.0.so.0+0x36749]  g_log+0x29
C  [libgtk-x11-2.0.so.0+0x25e13b]  gtk_widget_size_allocate+0x2ab
C  [libswt-pi-gtk-3236.so+0x36954]  Java_org_eclipse_swt_internal_gtk_OS__1gtk_1widget_1size_1allocate+0x44
j  org.eclipse.swt.internal.gtk.OS._gtk_widget_size_allocate(ILorg/eclipse/swt/internal/gtk/GtkAllocation;)V+0
j  org.eclipse.swt.internal.gtk.OS.gtk_widget_size_allocate(ILorg/eclipse/swt/internal/gtk/GtkAllocation;)V+9
j  org.eclipse.swt.widgets.Shell.forceResize(II)V+63
j  org.eclipse.swt.widgets.Shell.resizeBounds(IIZ)V+73
j  org.eclipse.swt.widgets.Shell.setBounds(IIIIZZ)I+300
j  org.eclipse.swt.widgets.Control.setBounds(Lorg/eclipse/swt/graphics/Rectangle;)V+40
j  org.gudy.azureus2.ui.swt.shells.MessageSlideShell$1.run()V+119
j  org.eclipse.swt.widgets.RunnableLock.run()V+11
j  org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Z)Z+29
J  org.eclipse.swt.widgets.Display.readAndDispatch()Z
j  org.gudy.azureus2.ui.swt.mainwindow.SWTThread.<init>(Lcom/aelitis/azureus/ui/IUIIntializer;)V+161
j  org.gudy.azureus2.ui.swt.mainwindow.SWTThread.createInstance(Lcom/aelitis/azureus/ui/IUIIntializer;)V+33
j  org.gudy.azureus2.ui.swt.mainwindow.Initializer.<init>(Lcom/aelitis/azureus/core/AzureusCore;Lorg/gudy/azureus2/ui/swt/StartServer;[Ljava/lang/String;)V+76
j  org.gudy.azureus2.ui.swt.Main.<init>([Ljava/lang/String;)V+447
j  org.gudy.azureus2.ui.swt.Main.main([Ljava/lang/String;)V+4
v  ~StubRoutines::call_stub
V  [libjvm.so+0x20967d]
V  [libjvm.so+0x3057d8]
V  [libjvm.so+0x209510]
V  [libjvm.so+0x232916]
V  [libjvm.so+0x223fbb]
C  [java+0x1b98]  JavaMain+0x2c8
C  [libpthread.so.0+0x531b]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x08870800 JavaThread "Slidey" daemon [_thread_in_vm, id=12578]
  0x081b3800 JavaThread "TRTrackerServer:accept.loop" daemon [_thread_in_native, id=12577]
  0x081f5000 JavaThread "TrackerServer:timer.loop" daemon [_thread_blocked, id=12576]
  0x081e5400 JavaThread "Simple Timer[9]" daemon [_thread_blocked, id=12545]
  0x082ea400 JavaThread "Simple Timer[7]" daemon [_thread_blocked, id=12497]
  0x082e9800 JavaThread "Simple Timer[6]" daemon [_thread_blocked, id=12496]
  0x08218800 JavaThread "DHTControl:internallookups[10]" daemon [_thread_blocked, id=12493]
  0x08217800 JavaThread "DHTControl:internallookups[9]" daemon [_thread_blocked, id=12492]
  0x08216800 JavaThread "DHTControl:internallookups[8]" daemon [_thread_blocked, id=12491]
  0x08215800 JavaThread "DHTControl:internallookups[7]" daemon [_thread_blocked, id=12490]
  0x08214800 JavaThread "DHTControl:internallookups[6]" daemon [_thread_blocked, id=12489]
  0x08213800 JavaThread "DHTControl:internallookups[5]" daemon [_thread_blocked, id=12488]
  0x08212800 JavaThread "DHTControl:internallookups[4]" daemon [_thread_blocked, id=12487]
  0x08212000 JavaThread "DHTControl:internallookups[3]" daemon [_thread_blocked, id=12486]
  0x08211800 JavaThread "DHTControl:internallookups[2]" daemon [_thread_blocked, id=12485]
  0x086dac00 JavaThread "PRUDPPacketHandler:receiver" daemon [_thread_blocked, id=12421]
  0x08834800 JavaThread "DHTControl:internallookups[1]" daemon [_thread_blocked, id=12411]
  0x087bf400 JavaThread "PRUDPPacketHandler:sender" daemon [_thread_blocked, id=12410]
  0x0878e400 JavaThread "GUI updater" [_thread_blocked, id=12398]
  0x08776c00 JavaThread "Timer:Process Data Sources" daemon [_thread_blocked, id=12397]
  0x08765c00 JavaThread "Timer:Process Data Sources" daemon [_thread_blocked, id=12396]
  0x086e1800 JavaThread "Universal Plug and Play (UPnP)::SSDP:queryLoop" daemon [_thread_blocked, id=12392]
  0x086ea800 JavaThread "MCGroup:CtrlListener" daemon [_thread_in_native, id=12391]
  0x086e9800 JavaThread "MCGroup:MCListener" daemon [_thread_in_native, id=12390]
  0x086dc400 JavaThread "MCGroup:CtrlListener" daemon [_thread_in_native, id=12386]
  0x086de400 JavaThread "MCGroup:MCListener" daemon [_thread_in_native, id=12385]
  0x086f5c00 JavaThread "MagnetURIHandler" daemon [_thread_in_native, id=12382]
  0x086cec00 JavaThread "HostNameToIPResolver" daemon [_thread_blocked, id=12381]
  0x086d9400 JavaThread "TRHost:ListenDispatcher" daemon [_thread_blocked, id=12380]
  0x086cdc00 JavaThread "SpeedScheduler" daemon [_thread_blocked, id=12379]
  0x086b1000 JavaThread "StatsWriter" daemon [_thread_blocked, id=12378]
  0x086a9c00 JavaThread "Global Status Checker" [_thread_blocked, id=12377]
  0x086a7c00 JavaThread "TRHost::stats.loop" daemon [_thread_blocked, id=12376]
  0x085e5800 JavaThread "Tracker Scrape" daemon [_thread_blocked, id=12375]
  0x085e7000 JavaThread "GM:ListenDispatcher" daemon [_thread_blocked, id=12374]
  0x0834dc00 JavaThread "Start Server" daemon [_thread_in_native, id=12360]
  0x0834cc00 JavaThread "NetworkGlueUDP" daemon [_thread_blocked, id=12359]
  0x0834b800 JavaThread "PRUDPPacketReciever:37020" daemon [_thread_in_native, id=12358]
  0x08340400 JavaThread "WriteController:WriteSelector" daemon [_thread_in_native, id=12357]
  0x08341800 JavaThread "ReadController:ReadSelector" daemon [_thread_in_native, id=12356]
  0x08344c00 JavaThread "VServerSelector:port37020" daemon [_thread_in_native, id=12355]
  0x0833f400 JavaThread "ConnectDisconnectManager" daemon [_thread_in_native, id=12354]
  0x08329c00 JavaThread "ReadController:ReadProcessor" daemon [_thread_blocked, id=12353]
  0x08326800 JavaThread "WriteController:WriteProcessor" daemon [_thread_blocked, id=12352]
  0x082da800 JavaThread "Timer:Simple Timer" daemon [_thread_blocked, id=12351]
  0x082d5000 JavaThread "SystemTime" daemon [_thread_blocked, id=12350]
  0x0808e000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=12348]
  0x0808c800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=12347]
  0x0808b400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=12346]
  0x08082000 JavaThread "Finalizer" daemon [_thread_blocked, id=12345]
  0x08081000 JavaThread "Reference Handler" daemon [_thread_blocked, id=12344]
=>0x08058c00 JavaThread "main" [_thread_in_native, id=12342]
Other Threads:
  0x08077800 VMThread [id=12343]
  0x0808f800 WatcherThread [id=12349]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 960K, used 654K [0x8c0e0000, 0x8c1e0000, 0x8c5c0000)
  eden space 896K,  66% used [0x8c0e0000, 0x8c1753e8, 0x8c1c0000)
  from space 64K,  89% used [0x8c1d0000, 0x8c1de488, 0x8c1e0000)
  to   space 64K,   0% used [0x8c1c0000, 0x8c1c0000, 0x8c1d0000)
 tenured generation   total 4868K, used 4665K [0x8c5c0000, 0x8ca81000, 0x900e0000)
   the space 4868K,  95% used [0x8c5c0000, 0x8ca4e7e0, 0x8ca4e800, 0x8ca81000)
 compacting perm gen  total 12288K, used 11982K [0x900e0000, 0x90ce0000, 0x940e0000)
   the space 12288K,  97% used [0x900e0000, 0x90c939d8, 0x90c93a00, 0x90ce0000)
    ro space 8192K,  73% used [0x940e0000, 0x946be548, 0x946be600, 0x948e0000)
    rw space 12288K,  57% used [0x948e0000, 0x94fd16c0, 0x94fd1800, 0x954e0000)
Dynamic libraries:
06000000-06412000 r-xp 00000000 03:01 52215      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/libjvm.so
06412000-0642b000 rwxp 00411000 03:01 52215      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/libjvm.so
0642b000-0684a000 rwxp 0642b000 00:00 0
08048000-08052000 r-xp 00000000 03:01 52189      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/bin/java
08052000-08053000 rwxp 00009000 03:01 52189      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/bin/java
08053000-08912000 rwxp 08053000 00:00 0          [heap]
8c0e0000-8c1e0000 rwxp 8c0e0000 00:00 0
8c1e0000-8c5c0000 rwxp 8c1e0000 00:00 0
8c5c0000-8ca81000 rwxp 8c5c0000 00:00 0
8ca81000-900e0000 rwxp 8ca81000 00:00 0
900e0000-90ce0000 rwxp 900e0000 00:00 0
90ce0000-940e0000 rwxp 90ce0000 00:00 0
940e0000-946bf000 r-xs 00001000 03:01 52330      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/classes.jsa
946bf000-948e0000 rwxp 946bf000 00:00 0
948e0000-94fd2000 rwxp 005e0000 03:01 52330      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/classes.jsa
94fd2000-954e0000 rwxp 94fd2000 00:00 0
954e0000-955b9000 rwxp 00cd2000 03:01 52330      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/classes.jsa
955b9000-958e0000 rwxp 955b9000 00:00 0
958e0000-958e4000 r-xs 00dab000 03:01 52330      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client/classes.jsa
958e4000-95ce0000 rwxp 958e4000 00:00 0
b1cbd000-b1cc0000 ---p b1cbd000 00:00 0
b1cc0000-b1d0e000 rwxp b1cc0000 00:00 0
b1d0e000-b1d11000 ---p b1d0e000 00:00 0
b1d11000-b1d5f000 rwxp b1d11000 00:00 0
b1d5f000-b1d62000 ---p b1d5f000 00:00 0
b1d62000-b1db0000 rwxp b1d62000 00:00 0
b1db0000-b1e26000 r-xp 00000000 03:01 9210269    /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans-Bold.ttf
b1e26000-b1e29000 ---p b1e26000 00:00 0
b1e29000-b1e77000 rwxp b1e29000 00:00 0
b1e77000-b1e7a000 ---p b1e77000 00:00 0
b1e7a000-b1ec8000 rwxp b1e7a000 00:00 0
b1ec8000-b1ecb000 ---p b1ec8000 00:00 0
b1ecb000-b1f19000 rwxp b1ecb000 00:00 0
b1f19000-b1f1c000 ---p b1f19000 00:00 0
b1f1c000-b1f6a000 rwxp b1f1c000 00:00 0
b1f6a000-b1f6d000 ---p b1f6a000 00:00 0
b1f6d000-b1fbb000 rwxp b1f6d000 00:00 0
b1fbb000-b1fbe000 ---p b1fbb000 00:00 0
b1fbe000-b200c000 rwxp b1fbe000 00:00 0
b200c000-b200f000 ---p b200c000 00:00 0
b200f000-b205d000 rwxp b200f000 00:00 0
b205d000-b2060000 ---p b205d000 00:00 0
b2060000-b20ae000 rwxp b2060000 00:00 0
b20ae000-b20b1000 ---p b20ae000 00:00 0
b20b1000-b20ff000 rwxp b20b1000 00:00 0
b20ff000-b2102000 ---p b20ff000 00:00 0
b2102000-b2150000 rwxp b2102000 00:00 0
b2150000-b2153000 ---p b2150000 00:00 0
b2153000-b21a1000 rwxp b2153000 00:00 0
b21a1000-b21a4000 ---p b21a1000 00:00 0
b21a4000-b21f2000 rwxp b21a4000 00:00 0
b21f2000-b21f5000 ---p b21f2000 00:00 0
b21f5000-b2243000 rwxp b21f5000 00:00 0
b2243000-b2246000 ---p b2243000 00:00 0
b2246000-b2294000 rwxp b2246000 00:00 0
b2294000-b2297000 ---p b2294000 00:00 0
b2297000-b22e5000 rwxp b2297000 00:00 0
b22e5000-b22e8000 ---p b22e5000 00:00 0
b22e8000-b2336000 rwxp b22e8000 00:00 0
b2336000-b2339000 ---p b2336000 00:00 0
b2339000-b2387000 rwxp b2339000 00:00 0
b2387000-b238a000 ---p b2387000 00:00 0
b238a000-b23d8000 rwxp b238a000 00:00 0
b23d8000-b23db000 ---p b23d8000 00:00 0
b23db000-b2429000 rwxp b23db000 00:00 0
b2429000-b242c000 ---p b2429000 00:00 0
b242c000-b247a000 rwxp b242c000 00:00 0
b247a000-b247d000 ---p b247a000 00:00 0
b247d000-b24cb000 rwxp b247d000 00:00 0
b24cb000-b24ce000 ---p b24cb000 00:00 0
b24ce000-b251c000 rwxp b24ce000 00:00 0
b251c000-b252b000 r-xp 00000000 03:01 2671902    /lib/tls/i686/cmov/libresolv-2.5.so
b252b000-b252d000 rwxp 0000f000 03:01 2671902    /lib/tls/i686/cmov/libresolv-2.5.so
b252d000-b252f000 rwxp b252d000 00:00 0
b252f000-b2533000 r-xp 00000000 03:01 2671889    /lib/tls/i686/cmov/libnss_dns-2.5.so
b2533000-b2535000 rwxp 00003000 03:01 2671889    /lib/tls/i686/cmov/libnss_dns-2.5.so
b2535000-b2537000 r-xp 00000000 03:01 2637913    /lib/libnss_mdns4_minimal.so.2
b2537000-b2538000 rwxp 00001000 03:01 2637913    /lib/libnss_mdns4_minimal.so.2
b2546000-b2549000 ---p b2546000 00:00 0
b2549000-b2597000 rwxp b2549000 00:00 0
b2597000-b259a000 ---p b2597000 00:00 0
b259a000-b25e8000 rwxp b259a000 00:00 0
b25e8000-b25eb000 ---p b25e8000 00:00 0
b25eb000-b2639000 rwxp b25eb000 00:00 0
b2639000-b263c000 ---p b2639000 00:00 0
b263c000-b268a000 rwxp b263c000 00:00 0
b268a000-b2698000 r-xs 00656000 03:01 52325      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/charsets.jar
b2698000-b269b000 ---p b2698000 00:00 0
b269b000-b26e9000 rwxp b269b000 00:00 0
b26e9000-b26ec000 ---p b26e9000 00:00 0
b26ec000-b273a000 rwxp b26ec000 00:00 0
b273a000-b273d000 ---p b273a000 00:00 0
b273d000-b278b000 rwxp b273d000 00:00 0
b278b000-b278e000 ---p b278b000 00:00 0
b278e000-b27dc000 rwxp b278e000 00:00 0
b27dc000-b27df000 ---p b27dc000 00:00 0
b27df000-b282d000 rwxp b27df000 00:00 0
b282d000-b282f000 r-xp 00000000 03:01 9126425    /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b282f000-b2830000 rwxp 00001000 03:01 9126425    /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
b2830000-b28ad000 r-xp 00000000 03:01 9210273    /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
b28ad000-b28b3000 r-xs 00000000 03:01 7913551
the rest of the error:
Code:
/var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.cache-2
b28b3000-b28b4000 r-xs 00000000 03:01 7913579    /var/cache/fontconfig/fd9505950c048a77dc4b710eb6a628ed-x86.cache-2
b28b4000-b28b7000 r-xs 00000000 03:01 7913567    /var/cache/fontconfig/ddc79d3ea06a7c6ffa86ede85f3bb5df-x86.cache-2
b28b7000-b28b8000 r-xs 00000000 03:01 7913573    /var/cache/fontconfig/e7071f4a29fa870f4323321c154eba04-x86.cache-2
b28b8000-b28b9000 r-xs 00000000 03:01 7913554    /var/cache/fontconfig/a2ab74764b07279e7c36ddb1d302cf26-x86.cache-2
b28b9000-b28bd000 r-xs 00000000 03:01 7913548    /var/cache/fontconfig/921a30a17f0be15c70ac14043cb7a739-x86.cache-2
b28bd000-b28c0000 r-xs 00000000 03:01 7914098    /var/cache/fontconfig/926e794c3d5e5dffcaf2fa83ef8d36c2-x86.cache-2
b28c0000-b28c1000 r-xs 00000000 03:01 7913536    /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-x86.cache-2
b28c1000-b28c3000 r-xs 00000000 03:01 7913541    /var/cache/fontconfig/646addb8444faa74ee138aa00ab0b6a0-x86.cache-2
b28c3000-b28c5000 r-xs 00000000 03:01 7913529    /var/cache/fontconfig/20bd79ad97094406f7d1b9654bfbd926-x86.cache-2
b28c5000-b28c6000 r-xs 00000000 03:01 7913544    /var/cache/fontconfig/75a2cd575a62c63e802c11411fb87c37-x86.cache-2
b28c6000-b28c8000 r-xs 00000000 03:01 7913552    /var/cache/fontconfig/9c0624108b9a2ae8552f664125be8356-x86.cache-2
b28c8000-b28ce000 r-xs 00000000 03:01 7913542    /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.cache-2
b28ce000-b28d0000 r-xs 00000000 03:01 7913568    /var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-x86.cache-2
b28d0000-b28d2000 r-xs 00000000 03:01 7913565    /var/cache/fontconfig/da1bd5ca8443ffe22927a23ce431d198-x86.cache-2
b28d2000-b28da000 r-xs 00000000 03:01 7913571    /var/cache/fontconfig/e3de0de479f42330eadf588a55fb5bf4-x86.cache-2
b28da000-b28e0000 r-xs 00000000 03:01 7913525    /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-x86.cache-2
b28e0000-b28e1000 r-xs 00000000 03:01 7913534    /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86.cache-2
b28e1000-b28e3000 r-xs 00000000 03:01 7913569    /var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86.cache-2
b28e3000-b28e9000 r-xs 00000000 03:01 7913563    /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-x86.cache-2
b28e9000-b28ec000 r-xs 00000000 03:01 7913540    /var/cache/fontconfig/6386b86020ecc1ef9690bb720a13964f-x86.cache-2
b28ec000-b28f0000 r-xs 00000000 03:01 7913523    /var/cache/fontconfig/089dead882dea3570ffc31a9898cfb69-x86.cache-2
b28f0000-b28f2000 r-xs 00000000 03:01 7913863    /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86.cache-2
b28f2000-b28f3000 r-xs 00000000 03:01 7913577    /var/cache/fontconfig/fcff1cd55d48a2c86a175e9943c3506d-x86.cache-2
b28f3000-b28f4000 r-xs 00000000 03:01 7913574    /var/cache/fontconfig/e9e44584608a73233979f764b5f9dd81-x86.cache-2
b28f4000-b28f5000 r-xs 00000000 03:01 7913559    /var/cache/fontconfig/b5a4f3f568a71026ccdc6a3a51afa9b4-x86.cache-2
b28f5000-b28f6000 r-xs 00000000 03:01 7913530    /var/cache/fontconfig/2561679576a9c7fd2ce41d281d4e00d1-x86.cache-2
b28f6000-b28f7000 r-xs 00000000 03:01 7913560    /var/cache/fontconfig/b8613a33de00eecd32d5a94c3c617829-x86.cache-2
b28f7000-b28fa000 r-xs 00000000 03:01 7913556    /var/cache/fontconfig/b21a91cee725896328b8cee8091cf747-x86.cache-2
b28fa000-b28ff000 r-xs 00000000 03:01 7913578    /var/cache/fontconfig/fd9416c4b92f07c6f59a3a8cf496e9dc-x86.cache-2
b28ff000-b2901000 r-xs 00000000 03:01 7913522    /var/cache/fontconfig/059138ec877db160474b4d5de1248d14-x86.cache-2
b2901000-b2902000 r-xs 00000000 03:01 7913575    /var/cache/fontconfig/f5a93ac943883aa0fd9a7bfe0f6ec3c1-x86.cache-2
b2902000-b2904000 r-xs 00000000 03:01 7913527    /var/cache/fontconfig/118d8d5311348bbdf5fe3b106d7c13d4-x86.cache-2
b2904000-b2905000 r-xs 00000000 03:01 7913553    /var/cache/fontconfig/a1131b7be650f9abae4907495aa5815d-x86.cache-2
b2905000-b290a000 r-xs 00000000 03:01 7913547    /var/cache/fontconfig/8ab5f685cd6d8ba67c37c908faf08172-x86.cache-2
b290a000-b290e000 r-xs 00000000 03:01 7913524    /var/cache/fontconfig/0f32d3adc6a232110812e17374eaa446-x86.cache-2
b290e000-b2913000 r-xs 00000000 03:01 7914095    /var/cache/fontconfig/7b4a97c10f6c0166998ddfa1cf7392fb-x86.cache-2
b2913000-b2916000 r-xs 00000000 03:01 7913537    /var/cache/fontconfig/61c830dfac3fd78a12654da5e9ba3f56-x86.cache-2
b2916000-b2917000 r-xs 00000000 03:01 7913570    /var/cache/fontconfig/e0f9e95429e756d56293ed4d63866094-x86.cache-2
b2917000-b2919000 r-xs 00000000 03:01 7913532    /var/cache/fontconfig/4123634e9c08547d899d0aaff05ebe69-x86.cache-2
b2919000-b291d000 r-xs 00000000 03:01 7913528    /var/cache/fontconfig/142ecfc435bad6f1fbc2648c1119d5eb-x86.cache-2
b291d000-b2923000 r-xs 00000000 03:01 7913526    /var/cache/fontconfig/102e5142c2e9e50c5e8ece26694a2dad-x86.cache-2
b2923000-b2924000 r-xs 00000000 03:01 7913549    /var/cache/fontconfig/92a571655fb1c0ec1c4d6f496220600a-x86.cache-2
b2924000-b292c000 r-xs 00000000 03:01 7913555    /var/cache/fontconfig/a960c40fc9306f090224a04585f8a963-x86.cache-2
b292c000-b292e000 r-xs 00000000 03:01 7913550    /var/cache/fontconfig/9404ff413c67fc2a1526fd14eb4163a8-x86.cache-2
b292e000-b2931000 r-xs 00000000 03:01 7913557    /var/cache/fontconfig/b3fedf7c409f006ca1a6fceffceb77cf-x86.cache-2
b2931000-b2933000 r-xs 00000000 03:01 7913538    /var/cache/fontconfig/6330322105e0c4105d7c7a6ea2974107-x86.cache-2
b2933000-b2935000 r-xs 00000000 03:01 7913859    /var/cache/fontconfig/beeeeb3dfe132a8a0633a017c99ce0c0-x86.cache-2
b2935000-b2937000 r-xp 00000000 03:01 9404582    /usr/share/locale-langpack/en_GB/LC_MESSAGES/atk10.mo
b2937000-b2997000 rwxs 00000000 00:08 17236008   /SYSV00000000 (deleted)
b2997000-b299a000 rwxs 00000000 00:08 17203228   /SYSV00000000 (deleted)
b299a000-b299d000 r-xs 00029000 03:01 82529      /usr/share/azureus/plugins/azplugins/azplugins_2.1.1.jar
b299d000-b29fd000 rwxs 00000000 00:08 17170458   /SYSV00000000 (deleted)
b29fd000-b2c0f000 r-xp 00000000 03:01 9323646    /usr/share/icons/hicolor/icon-theme.cache
b2c0f000-b3cf9000 r-xp 00000000 03:01 9507043    /usr/share/icons/crystalsvg/icon-theme.cache
b3cf9000-b43a2000 r-xp 00000000 03:01 9323644    /usr/share/icons/gnome/icon-theme.cache
b43a2000-b45f9000 r-xp 00000000 03:01 9326226    /usr/share/icons/Tango/icon-theme.cache
b45f9000-b469a000 r-xp 00000000 03:01 9326224    /usr/share/icons/Tangerine/icon-theme.cache
b469a000-b46a7000 r-xp 00000000 03:01 9062464    /usr/lib/jni/libglibjni-0.4.so
b46a7000-b46a8000 rwxp 0000c000 03:01 9062464    /usr/lib/jni/libglibjni-0.4.so
b46a8000-b475b000 r-xp 00000000 03:01 9062462    /usr/lib/jni/libgtkjni-2.10.so
b475b000-b475e000 rwxp 000b3000 03:01 9062462    /usr/lib/jni/libgtkjni-2.10.so
b475e000-b4761000 ---p b475e000 00:00 0
b4761000-b47af000 rwxp b4761000 00:00 0
b47af000-b47ce000 r-xp 00000000 03:01 9404738    /usr/share/locale-langpack/en_GB/LC_MESSAGES/libc.mo
b47ce000-b4806000 r-xp 00000000 03:01 9062457    /usr/lib/jni/libswt-gtk-3236.so
b4806000-b4808000 rwxp 00037000 03:01 9062457    /usr/lib/jni/libswt-gtk-3236.so
b4808000-b4809000 rwxp b4808000 00:00 0
b4809000-b4829000 r-xp 00000000 03:01 9404711    /usr/share/locale-langpack/en_GB/LC_MESSAGES/gtk20-properties.mo
b4829000-b4900000 r-xp 00000000 03:01 9045255    /usr/lib/locale/en_GB.utf8/LC_COLLATE
b4900000-b4921000 rwxp b4900000 00:00 0
b4921000-b4a00000 ---p b4921000 00:00 0
b4a01000-b4a05000 r-xs 00043000 03:41 4342784    /home/hamish/.azureus/plugins/sschedule/SpeedScheduler_1.3.1.jar
b4a05000-b4a07000 r-xs 00011000 03:01 82532      /usr/share/azureus/plugins/bdcc/bdcc_2.2.2.jar
b4a07000-b4a0c000 r-xp 00000000 03:01 9404663    /usr/share/locale-langpack/en_GB/LC_MESSAGES/glib20.mo
b4a0c000-b4a1d000 r-xp 00000000 03:01 9044386    /usr/lib/gtk-2.0/2.10.0/engines/libglide.so
b4a1d000-b4a1e000 rwxp 00010000 03:01 9044386    /usr/lib/gtk-2.0/2.10.0/engines/libglide.so
b4a1e000-b4a2d000 r-xp 00000000 03:01 9404712    /usr/share/locale-langpack/en_GB/LC_MESSAGES/gtk20.mo
b4a2d000-b4a4b000 r-xp 00000000 03:01 8996286    /usr/lib/libexpat.so.1.0.0
b4a4b000-b4a4d000 rwxp 0001d000 03:01 8996286    /usr/lib/libexpat.so.1.0.0
b4a4d000-b4a6f000 r-xp 00000000 03:01 8996699    /usr/lib/libpng12.so.0.15.0
b4a6f000-b4a70000 rwxp 00021000 03:01 8996699    /usr/lib/libpng12.so.0.15.0
b4a70000-b4a74000 r-xp 00000000 03:01 8996101    /usr/lib/libXdmcp.so.6.0.0
b4a74000-b4a75000 rwxp 00003000 03:01 8996101    /usr/lib/libXdmcp.so.6.0.0
b4a75000-b4a77000 r-xp 00000000 03:01 8996090    /usr/lib/libXau.so.6.0.0
b4a77000-b4a78000 rwxp 00001000 03:01 8996090    /usr/lib/libXau.so.6.0.0
b4a78000-b4a8b000 r-xp 00000000 03:01 8996845    /usr/lib/libz.so.1.2.3
b4a8b000-b4a8c000 rwxp 00012000 03:01 8996845    /usr/lib/libz.so.1.2.3
b4a8c000-b4af4000 r-xp 00000000 03:01 8994858    /usr/lib/libfreetype.so.6.3.10
b4af4000-b4af7000 rwxp 00068000 03:01 8994858    /usr/lib/libfreetype.so.6.3.10
b4af7000-b4b21000 r-xp 00000000 03:01 8996678    /usr/lib/libpangoft2-1.0.so.0.1600.2
b4b21000-b4b22000 rwxp 0002a000 03:01 8996678    /usr/lib/libpangoft2-1.0.so.0.1600.2
b4b22000-b4b2a000 r-xp 00000000 03:01 8996097    /usr/lib/libXcursor.so.1.0.2
b4b2a000-b4b2b000 rwxp 00007000 03:01 8996097    /usr/lib/libXcursor.so.1.0.2
b4b2b000-b4b30000 r-xp 00000000 03:01 8996125    /usr/lib/libXrandr.so.2.1.0
b4b30000-b4b31000 rwxp 00005000 03:01 8996125    /usr/lib/libXrandr.so.2.1.0
b4b31000-b4b38000 r-xp 00000000 03:01 8996113    /usr/lib/libXi.so.6.0.0
b4b38000-b4b39000 rwxp 00006000 03:01 8996113    /usr/lib/libXi.so.6.0.0
b4b39000-b4b3b000 r-xp 00000000 03:01 8996115    /usr/lib/libXinerama.so.1.0.0
b4b3b000-b4b3c000 rwxp 00001000 03:01 8996115    /usr/lib/libXinerama.so.1.0.0
b4b3c000-b4b43000 r-xp 00000000 03:01 8996127    /usr/lib/libXrender.so.1.3.0
b4b43000-b4b44000 rwxp 00006000 03:01 8996127    /usr/lib/libXrender.so.1.3.0
b4b44000-b4b67000 r-xp 00000000 03:01 8996292    /usr/lib/libfontconfig.so.1.2.0
b4b67000-b4b6f000 rwxp 00023000 03:01 8996292    /usr/lib/libfontconfig.so.1.2.0
b4b6f000-b4b7c000 r-xp 00000000 03:01 8996105    /usr/lib/libXext.so.6.4.0
b4b7c000-b4b7d000 rwxp 0000d000 03:01 8996105    /usr/lib/libXext.so.6.4.0
b4b7d000-b4beb000 r-xp 00000000 03:01 8996194    /usr/lib/libcairo.so.2.11.1
b4beb000-b4bed000 rwxp 0006d000 03:01 8996194    /usr/lib/libcairo.so.2.11.1
b4bed000-b4c81000 r-xp 00000000 03:01 8996387    /usr/lib/libglib-2.0.so.0.1200.11
b4c81000-b4c82000 rwxp 00093000 03:01 8996387    /usr/lib/libglib-2.0.so.0.1200.11
b4c82000-b4c84000 r-xp 00000000 03:01 8996397    /usr/lib/libgmodule-2.0.so.0.1200.11
b4c84000-b4c85000 rwxp 00002000 03:01 8996397    /usr/lib/libgmodule-2.0.so.0.1200.11
b4c85000-b4cbe000 r-xp 00000000 03:01 8996441    /usr/lib/libgobject-2.0.so.0.1200.11
b4cbe000-b4cbf000 rwxp 00039000 03:01 8996441    /usr/lib/libgobject-2.0.so.0.1200.11
b4cbf000-b4cd8000 r-xp 00000000 03:01 8996161    /usr/lib/libatk-1.0.so.0.1809.1
b4cd8000-b4cda000 rwxp 00018000 03:01 8996161    /usr/lib/libatk-1.0.so.0.1809.1
b4cda000-b4cde000 r-xp 00000000 03:01 8996107    /usr/lib/libXfixes.so.3.1.0
b4cde000-b4cdf000 rwxp 00003000 03:01 8996107    /usr/lib/libXfixes.so.3.1.0
b4cdf000-b4dcc000 r-xp 00000000 03:01 8996084    /usr/lib/libX11.so.6.2.0
b4dcc000-b4dd0000 rwxp 000ed000 03:01 8996084    /usr/lib/libX11.so.6.2.0
b4dd0000-b4e0c000 r-xp 00000000 03:01 8996674    /usr/lib/libpango-1.0.so.0.1600.2
b4e0c000-b4e0e000 rwxp 0003b000 03:01 8996674    /usr/lib/libpango-1.0.so.0.1600.2
b4e0e000-b4e15000 r-xp 00000000 03:01 8996676    /usr/lib/libpangocairo-1.0.so.0.1600.2
b4e15000-b4e16000 rwxp 00007000 03:01 8996676    /usr/lib/libpangocairo-1.0.so.0.1600.2
b4e16000-b4e99000 r-xp 00000000 03:01 8996349    /usr/lib/libgdk-x11-2.0.so.0.1000.11
b4e99000-b4e9c000 rwxp 00083000 03:01 8996349    /usr/lib/libgdk-x11-2.0.so.0.1000.11
b4e9c000-b4eb2000 r-xp 00000000 03:01 8996351    /usr/lib/libgdk_pixbuf-2.0.so.0.1000.11
b4eb2000-b4eb3000 rwxp 00015000 03:01 8996351    /usr/lib/libgdk_pixbuf-2.0.so.0.1000.11
b4eb3000-b4eb7000 r-xp 00000000 03:01 8996133    /usr/lib/libXtst.so.6.1.0
b4eb7000-b4eb8000 rwxp 00003000 03:01 8996133    /usr/lib/libXtst.so.6.1.0
b4eb8000-b4ebc000 r-xp 00000000 03:01 8996495    /usr/lib/libgthread-2.0.so.0.1200.11
b4ebc000-b4ebd000 rwxp 00003000 03:01 8996495    /usr/lib/libgthread-2.0.so.0.1200.11
b4ebd000-b520e000 r-xp 00000000 03:01 8996498    /usr/lib/libgtk-x11-2.0.so.0.1000.11
b520e000-b5214000 rwxp 00351000 03:01 8996498    /usr/lib/libgtk-x11-2.0.so.0.1000.11
b5214000-b5215000 rwxp b5214000 00:00 0
b5216000-b5217000 r-xp 00000000 03:01 9207990    /usr/lib/gconv/ISO8859-1.so
b5217000-b5219000 rwxp 00000000 03:01 9207990    /usr/lib/gconv/ISO8859-1.so
b5219000-b521a000 r-xp 00000000 03:01 9045261    /usr/lib/locale/en_GB.utf8/LC_NUMERIC
b521a000-b521b000 r-xp 00000000 03:01 9045264    /usr/lib/locale/en_GB.utf8/LC_TIME
b521b000-b521c000 r-xp 00000000 03:01 9045259    /usr/lib/locale/en_GB.utf8/LC_MONETARY
b521c000-b521d000 r-xp 00000000 03:01 9060396    /usr/lib/locale/en_GB.utf8/LC_MESSAGES/SYS_LC_MESSAGES
b521d000-b521e000 r-xp 00000000 03:01 9045262    /usr/lib/locale/en_GB.utf8/LC_PAPER
b521e000-b521f000 r-xp 00000000 03:01 9045260    /usr/lib/locale/en_GB.utf8/LC_NAME
b521f000-b5220000 r-xp 00000000 03:01 9045254    /usr/lib/locale/en_GB.utf8/LC_ADDRESS
b5220000-b5221000 r-xp 00000000 03:01 9045263    /usr/lib/locale/en_GB.utf8/LC_TELEPHONE
b5221000-b5222000 r-xp 00000000 03:01 9045258    /usr/lib/locale/en_GB.utf8/LC_MEASUREMENT
b5222000-b5223000 r-xp 00000000 03:01 9045257    /usr/lib/locale/en_GB.utf8/LC_IDENTIFICATION
b5223000-b527b000 r-xp 00000000 03:01 9062458    /usr/lib/jni/libswt-pi-gtk-3236.so
b527b000-b527d000 rwxp 00058000 03:01 9062458    /usr/lib/jni/libswt-pi-gtk-3236.so
b527d000-b5280000 ---p b527d000 00:00 0
b5280000-b52ce000 rwxp b5280000 00:00 0
b52ce000-b52d1000 ---p b52ce000 00:00 0
b52d1000-b531f000 rwxp b52d1000 00:00 0
b531f000-b5322000 ---p b531f000 00:00 0
b5322000-b5370000 rwxp b5322000 00:00 0
b5370000-b5373000 r-xs 00013000 03:01 52324      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/jce.jar
b5373000-b5376000 ---p b5373000 00:00 0
b5376000-b53c4000 rwxp b5376000 00:00 0
b53c4000-b53c7000 ---p b53c4000 00:00 0
b53c7000-b5415000 rwxp b53c7000 00:00 0
b5415000-b5418000 ---p b5415000 00:00 0
b5418000-b5466000 rwxp b5418000 00:00 0
b5466000-b5469000 ---p b5466000 00:00 0
b5469000-b54b7000 rwxp b5469000 00:00 0
b54b7000-b54be000 r-xp 00000000 03:01 52227      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libnio.so
b54be000-b54bf000 rwxp 00006000 03:01 52227      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libnio.so
b54bf000-b54c2000 ---p b54bf000 00:00 0
b54c2000-b5510000 rwxp b54c2000 00:00 0
b5510000-b5513000 ---p b5510000 00:00 0
b5513000-b5561000 rwxp b5513000 00:00 0
b5561000-b556e000 r-xs 00093000 03:01 9163332    /usr/share/java/gtk2.10.jar
b556e000-b556f000 r-xs 00007000 03:01 9163222    /usr/share/java/cairo1.0.jar
b556f000-b5570000 r-xs 00005000 03:01 9163221    /usr/share/java/glib0.4.jar
b5570000-b5580000 r-xs 00183000 03:01 9112026    /usr/lib/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3.2.2.v3236.jar
b5580000-b5582000 r-xs 00006000 03:01 9163213    /usr/share/java/commons-cli-1.0.jar
b5582000-b5587000 r-xs 0002f000 03:01 9163218    /usr/share/java/log4j-1.2.13.jar
b5587000-b559e000 r-xs 000de000 03:01 9162415    /usr/share/java/bcprov.jar
b559e000-b55a1000 ---p b559e000 00:00 0
b55a1000-b55ef000 rwxp b55a1000 00:00 0
b55ef000-b55f2000 ---p b55ef000 00:00 0
b55f2000-b5640000 rwxp b55f2000 00:00 0
b5640000-b5647000 r-xs 00106000 03:01 52261      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/resources.jar
b5647000-b564a000 r-xs 00027000 03:01 52321      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/ext/sunjce_provider.jar
b564a000-b567a000 rwxp b564a000 00:00 0
b567a000-b57f4000 r-xs 02c68000 03:01 52279      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/rt.jar
b57f4000-b5807000 r-xp 00000000 03:01 52226      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libnet.so
b5807000-b5808000 rwxp 00013000 03:01 52226      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libnet.so
b5808000-b5883000 r-xs 006b2000 03:01 9164015    /usr/share/java/Azureus2.jar
b5883000-b5884000 ---p b5883000 00:00 0
b5884000-b5904000 rwxp b5884000 00:00 0
b5904000-b5907000 ---p b5904000 00:00 0
b5907000-b5955000 rwxp b5907000 00:00 0
b5955000-b5958000 ---p b5955000 00:00 0
b5958000-b59d6000 rwxp b5958000 00:00 0
b59d6000-b59d9000 ---p b59d6000 00:00 0
b59d9000-b5a27000 rwxp b59d9000 00:00 0
b5a27000-b5a2e000 r-xs 00000000 03:01 9208043    /usr/lib/gconv/gconv-modules.cache
b5a2e000-b5a69000 r-xp 00000000 03:01 9045256    /usr/lib/locale/en_GB.utf8/LC_CTYPE
b5a69000-b5a6c000 ---p b5a69000 00:00 0
b5a6c000-b5aba000 rwxp b5a6c000 00:00 0
b5aba000-b5abd000 ---p b5aba000 00:00 0
b5abd000-b5b0b000 rwxp b5abd000 00:00 0
b5b0b000-b5b0c000 ---p b5b0b000 00:00 0
b5b0c000-b5b9a000 rwxp b5b0c000 00:00 0
b5b9a000-b5bb4000 rwxp b5b9a000 00:00 0
b5bb4000-b5bb7000 rwxp b5bb4000 00:00 0
b5bb7000-b5bd2000 rwxp b5bb7000 00:00 0
b5bd2000-b5bd3000 rwxp b5bd2000 00:00 0
b5bd3000-b5bd4000 rwxp b5bd3000 00:00 0
b5bd4000-b5bd7000 rwxp b5bd4000 00:00 0
b5bd7000-b5bf2000 rwxp b5bd7000 00:00 0
b5bf2000-b5bf8000 rwxp b5bf2000 00:00 0
b5bf8000-b5c12000 rwxp b5bf8000 00:00 0
b5c12000-b5c27000 rwxp b5c12000 00:00 0
b5c27000-b5c9d000 rwxp b5c27000 00:00 0
b5c9d000-b5ee5000 rwxp b5c9d000 00:00 0
b5ee5000-b7c9d000 rwxp b5ee5000 00:00 0
b7c9d000-b7cac000 r-xp 00000000 03:01 52222      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libzip.so
b7cac000-b7cae000 rwxp 0000e000 03:01 52222      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libzip.so
b7cae000-b7cd1000 r-xp 00000000 03:01 52221      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libjava.so
b7cd1000-b7cd3000 rwxp 00023000 03:01 52221      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libjava.so
b7cd3000-b7cde000 r-xp 00000000 03:01 52220      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libverify.so
b7cde000-b7cdf000 rwxp 0000b000 03:01 52220      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/libverify.so
b7cdf000-b7ce8000 r-xp 00000000 03:01 2671891    /lib/tls/i686/cmov/libnss_files-2.5.so
b7ce8000-b7cea000 rwxp 00008000 03:01 2671891    /lib/tls/i686/cmov/libnss_files-2.5.so
b7cea000-b7cf2000 r-xp 00000000 03:01 2671895    /lib/tls/i686/cmov/libnss_nis-2.5.so
b7cf2000-b7cf4000 rwxp 00007000 03:01 2671895    /lib/tls/i686/cmov/libnss_nis-2.5.so
b7cf4000-b7cfb000 r-xp 00000000 03:01 2671887
/lib/tls/i686/cmov/libnss_compat-2.5.so
b7cfb000-b7cfd000 rwxp 00006000 03:01 2671887    /lib/tls/i686/cmov/libnss_compat-2.5.so
b7cfd000-b7d10000 r-xp 00000000 03:01 2671885    /lib/tls/i686/cmov/libnsl-2.5.so
b7d10000-b7d12000 rwxp 00012000 03:01 2671885    /lib/tls/i686/cmov/libnsl-2.5.so
b7d12000-b7d14000 rwxp b7d12000 00:00 0
b7d14000-b7d1a000 r-xs 00091000 03:01 52320      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/jsse.jar
b7d1a000-b7d22000 rwxs 00000000 03:01 4735028    /tmp/hsperfdata_hamish/12339
b7d22000-b7d29000 r-xp 00000000 03:01 2671904    /lib/tls/i686/cmov/librt-2.5.so
b7d29000-b7d2b000 rwxp 00006000 03:01 2671904    /lib/tls/i686/cmov/librt-2.5.so
b7d2b000-b7d2e000 ---p b7d2b000 00:00 0
b7d2e000-b7d7c000 rwxp b7d2e000 00:00 0
b7d7c000-b7da1000 r-xp 00000000 03:01 2671882    /lib/tls/i686/cmov/libm-2.5.so
b7da1000-b7da3000 rwxp 00024000 03:01 2671882    /lib/tls/i686/cmov/libm-2.5.so
b7da3000-b7da5000 rwxp b7da3000 00:00 0
b7da5000-b7ee0000 r-xp 00000000 03:01 2671874    /lib/tls/i686/cmov/libc-2.5.so
b7ee0000-b7ee1000 r-xp 0013b000 03:01 2671874    /lib/tls/i686/cmov/libc-2.5.so
b7ee1000-b7ee3000 rwxp 0013c000 03:01 2671874    /lib/tls/i686/cmov/libc-2.5.so
b7ee3000-b7ee6000 rwxp b7ee3000 00:00 0
b7ee6000-b7ee8000 r-xp 00000000 03:01 2671880    /lib/tls/i686/cmov/libdl-2.5.so
b7ee8000-b7eea000 rwxp 00001000 03:01 2671880    /lib/tls/i686/cmov/libdl-2.5.so
b7eea000-b7ef1000 r-xp 00000000 03:01 65538      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/jli/libjli.so
b7ef1000-b7ef3000 rwxp 00006000 03:01 65538      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/jli/libjli.so
b7ef3000-b7f06000 r-xp 00000000 03:01 2671900    /lib/tls/i686/cmov/libpthread-2.5.so
b7f06000-b7f08000 rwxp 00013000 03:01 2671900    /lib/tls/i686/cmov/libpthread-2.5.so
b7f08000-b7f0f000 rwxp b7f08000 00:00 0
b7f0f000-b7f15000 r-xp 00000000 03:01 52209      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/native_threads/libhpi.so
b7f15000-b7f16000 rwxp 00006000 03:01 52209      /usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/native_threads/libhpi.so
b7f16000-b7f17000 rwxp b7f16000 00:00 0
b7f17000-b7f18000 r-xp b7f17000 00:00 0
b7f18000-b7f1a000 rwxp b7f18000 00:00 0
b7f1a000-b7f33000 r-xp 00000000 03:01 2637845    /lib/ld-2.5.so
b7f33000-b7f35000 rwxp 00019000 03:01 2637845    /lib/ld-2.5.so
bf99b000-bf9b1000 rwxp bf99b000 00:00 0          [stack]
ffffe000-fffff000 r-xp 00000000 00:00 0          [vdso]
VM Arguments:
jvm_args: -Djava.library.path=/usr/lib/jni:/usr/lib -Dgnu.gcj.runtime.VMClassLoader.library_control=never -Dazureus.install.path=/home/hamish/.azureus
java_command: org.gudy.azureus2.ui.swt.Main
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games
USERNAME=hamish
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386/client:/usr/lib/jvm/java-6-sun-1.6.0.00/jre/lib/i386:/usr/lib/jvm/java-6-sun-1.6.0.00/jre/../lib/i386:/usr/lib/jni
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x3aea90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x3aea90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x304e70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x304e70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x304e70], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x306e80], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x3068a0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
---------------  S Y S T E M  ---------------
OS:4.0
uname:Linux 2.6.20-16-generic #2 SMP Thu Jun 7 20:19:32 UTC 2007 i686
libc:glibc 2.5 NPTL 2.5
rlimit: STACK 8192k, CORE 0k, NPROC infinity, NOFILE 1024, AS infinity
load average:1.60 1.39 1.75
CPU:total 1 family 6, cmov, cx8, fxsr, mmx, sse, mmxext, 3dnowext, 3dnow
Memory: 4k page, physical 515984k(14116k free), swap 1510068k(1476104k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0-b105) for linux-x86, built on Nov 29 2006 01:24:38 by "java_re" with gcc 3.2.1-7a (J2SE release)
