problem installing new network adapter
23 Mar 2007
Essex
Hi guys i just bought this wireless network adapter
Dynamode WLGI600XA 54mbps Wireless LAN PCI Adapter
This is the mo board i have
http://www.overclockers.co.uk/showproduct.php?prodid=MB-151-AS
I put the adapter in the bottom pci socket
i followed the instructions installed the drivers from the cd turned off pc installed card then turned on the green light on the back of the adapter never turned on but windows reconized there was new hardware i clicked next on the wizard to install automaticlly then three options came up cant remember what they were tho anyway it when u load the program up that was insatlled it says card unplugged, really dont no whats going on if someone could help me out id be so greatful
sorry i 4got to mention im using the bt voyager 2091 router
many thanks
try uninstalling the adaptor in device manager and download the latest drivers from the dynamode site, if your using a 64 bit OS it may not be supported
As I already said at the competitors forum where you posted the exact same thread, there are 2 different types of this card using chipsets from different manufacturers. Check what device manager recognizes yours to be and make sure you install the correct chipset driver.
