Problem Installing Windows 7
23 Dec 2009
Hi, need some help...
I'm trying to install windows on a new system.
When I come to where it asks what Hard Disk I want to install it on, nothing is displayed :confused:
This is a new HDD by the way. Do I need to partition it or something?
I believe I've installed it correctly, as I was able to set it to secondary in BIOS.
Any ideas? :confused:
Cheers
Unplug all HDDs from your system. Then reconnect the HDD Windows 7 is destined for, see if it shows up in the BIOS and during POST. Try the install again. Try different SATA ports on your mobo and try a different SATA cable.
If no joy, you could have a duff HDD. RMA time in that case.
