Hoping someone may have a suggestion to my problem. The PC is dual booting XP and LINUX using GRUB. However before you get to the GRUB menu I am getting a quick message at the POST screen that no keyboard has been detected. When the GRUB menu appears (as you would expect) I am uable to select an OS as there is no keyboard!
I usually use a Bluetooth key board, and have tried both PS2 and USB with the same result. Even putting the Xp disc in the DVD drive I grind to a halt when I am asked to 'press any key to boot from the CD'.
All connections inside the machine are OK, there appears to be nothing obvious.
Motherboard is an Asus A8N32-SLI Deluxe.The LINUX OS is on a seperate hard drive. (Enermax Liberty 620w PSU, 2 x 6800GS Graphics, AMD X2 4400 CPU, 2gb Corsair RAM)
Any suggestions would be gratefully recived.
DODGE
DODGE
