- 10 Dec 2009
Hi everyone
Currently my cpu is running at 266 x 9, 1.27 vcore and 1072mhz FSB. They are stock speeds and I would like to increase to atleast 356 x 9 for 3.2Ghz.
Now in BIOS I set the frequency to 356 and kept the multiplyer at 9. I See no options to change the vcore or FSB, I only see there values so I assume it automaticly changes? How ever when I save the changes and exit BIOS and the computer restarts. Then nothing, just the fan is on, monitor and other peripherals are off. I leave it for a while but it is still in the same state. So I then procede to press the restart button and it does nothing so I hold the on/off button for 5 seconds to force turn off.
After switching it back on it gets to the post screen and says "overclocking failed or overvolting failed please enter BIOS and revert back to default values".
So I try a different frequency, 333 but still no dice. I'v also tried updating the BIOS to the latest version but its still the same.
Specs:
Q6600 @2.4Ghz G0 stepping
ASUS P5KPL-VM mobo (updated BIOS)
4gb RAM @800Mhz
ATI 5870
80GB Intel SSD
Im using the corsair H50 as my CPU cooler so heat shouldn't be a problem and my current temps are:
CPU idle 15-25 degrees celcius.
I'v read the guide and I'm not sure if I'v missed anything so please any help is appreciated.
Specs:
4gb RAM @800Mhz
ATI 5870
80GB Intel SSD
