Problem overclocking with ATI Tray Tools
17 Jan 2005
Liverpool
I used to have it running fine, but for some reason, whatever clocks I apply in ATT they don't work when I run games or 3D Mark. It uses the stock 2D clocks. I have disabled both the ATI services and have also selected in ATT to kill it even if it was there...
The clocks are all set and if I hover over the ATT icon in the taskbar it says they're set. But when I run 3D Mark I only get 10k with is my 2D clocks score.
I unchecked the check box for the I2C thing in ATT when installing it and have tried reinstalling it many times...
Any ideas?
Cheers :)
Well I've found out that ATT is applying my clocks, because if I use the ATI automatic switching, I get even lower scores in 3D Mark.
However, for some reason, my scores aren't anywhere near what they used to be.
The one on the left was done with pretty much the same clocks as the one on the right but scores a lot lower. The one on the right was done when I first had my system, with the same drivers as the one on the left. I have tried updating my drivers since but it hasn't made any difference..
Any idea what the reason is for the lower score?
