Problem Overclocking
7 Jan 2008
Tunbridge Wells
I'm having problems overclocking my computer. I can't get a stable overclock (prime95 12 hours). I have tried locking the PCI bus, setting HT multiplier to 4x, made sure all stuff like ai overclock etc is disabled, upping vcore and chipset voltage a bit, as well as ram voltage. My aim to overclock my computer enough to allow my ram to run at full speed ie 3.2Ghz, as a start, but ideally like to go higher. My current temps are low 30s idle and low 50s load; i will obvisously by a better cooler if this is successful.
My computer is:
AMD 6000 X2 1.36v
Asus M2N32 Sli Deluxe
OCZ (4x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC - 4-4-4-15 2.00v
Sapphire x1950xt
Cosair HX520
Any help would be greatly appreciated
