Problem powering laptop
22 Jul 2006
Evening all,
Gf is having problems powering the laptop. This seems to have just happened tonight, problem is:
When powerpack is plugged into the laptop it seems to cut the power supply, one powerpack the 'power light' lights up when the end is not connected in the laptop, as soon as it is connected the green light goes out. With another powerpack as soon as the laptop is connected up there is a high pitch squeel that comes from the power pack.
I have tried it without the battery however the same problem occurs.
Is there a problem with the power connection within the laptop?
Any suggestions?
Thanks
The laptop is a Packard Bell Easynote W3910.
Looking up on the internet and it seems its quite common for the power supply in the laptop to fail.
How easy would this be to source a new one? Would overclockers be able to get hold of one you think?
Not 100% clued up on repairing laptops, 'I'm a pc'!
overclockers wont be able to get a packard bell easynote battery. no idea about sourcing one. are both the batteries you have original parts or is one or both of them made by some 3rd party company?
if the light on the ac adapter is going out when you plug it in this would suggest that the DC socket is shorting out or the pcb that it attached to is faulty, i think these had a small seperate dc/usb board connected to mainboard, it might be resolderable or it might be too burnt out, does the socket have a strange smell.
Yeah the socket has a strange smell when the adapter is connected to it.
Is this quite easy to fix or is it new laptop time?
it might just need the socket replacing or resoldering, either way its a full strip down to take the mainboard out, not too dificult of your handy with a screwdriver and have a bit of disassembly skills.
Worse case scenario is replacement mainboad which won't be cheap if you can find one.
Buy a power socket on one of the auction sites try to find a geek with soldering gun skills and tell him you give him £10 for replacing the socket and another £10 if it works.
I done it my self with a standard cheap soldering gun and about 5 hours of soldering gun experience. A dell laptop had no power going to the socket fixed in about 3 hours.
You migh want to obtain a service manual for your laptop so that you dont breake anything during dissassembly (unles you done things like that before). You ahve to have access to the power socket area from both sides of motherboard so you actualy have to do a 100% dissassembly.
Good luck
