Problem powering PC on
14 Feb 2008
Problem turning PC on, last week I upgraded my PC with a i5, Asus P8Z68-V Pro and some G-skill sniper ram 1.25v.
When I start my PC up for the first time each day, I have to turn my Asus P8Z68-V Pro on using the onboard power button and not the case button. Once working the case button works fine for turning the PC off, anyone come across this before?
As I am not sure what is causing this, I know it's not the case button as that was working fine on the old mobo. Also the system is fine once powered on.
1.25v might be too low for the memory controller on the 2500K, try 1.5v?
Not sure what else the problem could be if the switch works for turning off but not turning on :confused:. Maybe try a CMOS reset or a newer BIOS?
I found the problem it was the white block you put the reset wires and power button to, it had moved a couple of mill. I pushed the block down and tried the power button and it work fine, but it seems very lose.
So I may take it out and just plug the connectors straight to the board.
