Problem printing leaflet, please help
1 Oct 2004
Rowley Regis, West Mids
Hi all, please find attached leaflet I sent this to a printer to get them printed into A5 flyers and they have come back with the following errors
Your artwork does NOT meet print requirements:
- low resolution; for hi-quality prints we require 300dpi resolution,
- improper size / missing bleeds; for A5 flyers we require artwork in dimension: 150 x 212 mm,
- missing safety space; all objects (writings, logos, frames) apart from background picture should be placed at least 3mm away from the trim line, that's 4mm away from the edge when 1mm bleed used.
Could some please help me !!
http://www.mediafire.com/?v5ruv4p3dr2u6s2
Set it to CMYK Colour space, converted to 300PPI. Although your text under the roof was rasterised already.
Added 3mm bleed all round, and used a 5mm safety space. Added guides so you can see what I did. Final size is 216 x 154mm - without 3mm bleed all round is 148 x 210mm.
The roof is still 72PPI, I would redo that in my file if you wanted it to be really high quality.
http://kainey.co.uk/up/files/1/A5 Flyer08(alt lettering).psd
Done using CS5.
Done using CS5.
Thanks
