Problem running dual monitors with 2 Xservers (no Xinerama).
18 Feb 2006
I had this setup in Fedora C9, but I have now migrated over to Ubuntu 8.10. Basically, I want 2 X server sessions, one for each monitor, so I can load individual programs on each and and have them full screen. Basically, I end up with 2 'non interactive with each other' Desktops on 2 monitors that are differently sized (19" and 24").
OK, all well and good, sudo nvidia-settings, setup twin view and resolutions. Save to X, close and restart X. I come back to my desktop to get the 19" working, and the 24" half way there. I end up with a desktop 1440x900 in the top left corner which I can move applications from my desktop around and black border around the rest which I can only move my mouse cursor on. As soon as I interact with the menu bar X crashes.
So now I am stuck and need some help.
Thanks for the help.
Make sure Compiz is turned off. (Desktop Effects, none)
Or just type metacity --replace.
F9 was still using the old Xserver. Ub8.1 is using the new HAL dependent Xorg along with nvidias new wonky drivers. Best of luck getting this to work.
How do you go about setting up two separate screens like this? Could I have one display for my Kaffeine player and the other for normal desktop apps. both with different resolution? Running Mandriva 2008.1 and nVidia.
I have resolved the issue (Not sure how though but when I came back after work it was working correctly). Annoyingly I have now broken Sound, and may or may not have broken it more trying to fix it...
When playing the test sound I get:
audiotestsrc wave=sine freq=512 ! audioconvert ! audioresample ! gconfaudiosink: Could not open audio device for playback.
And in a attempt at fixing it I get "No volume control GStreamer plugins and/or devices found." When double clicking on the sound icon.
I have been using this guide: https://help.ubuntu.com/community/OpenSound and had it working before a restart. I didn't try sound again until the above restart. :(
Having 2 Xservers results in effectively having 2 Computers controlled by 1 mouse. I run (or will do) a music player and 2 VMware machines on the secondary and use the primary for general use. I run different resolutions and don't have a problem now. You can't drag applications between screens. Xinerama allows you to, but full screen apps do not work correctly.
Edit: After a restart I now have this error when playing the test tone: "gconfaudiosrc ! audioconvert ! audioresample ! gconfaudiosink profile=chat: Could not open audio device for playback. Device is being used by another application."
