I run a warband server on port 7240 It worked fine, the next day it stopped working completely??? I then change to port 7259 and it works fine. Next day same again it stops working.
Do I have to keep changing ports or is there something blocking the ports.
Only thing I can imagine causing it is that I dont have a static IP whats your thoughts on the problem?
