Problem setting up an HPC7200 wireless printer!
29 Oct 2002
stoke-on-trent
First problem, my mate is on AOL and I can't get into the router, rang AOL and they said ip 192.168.0.1 which gets me to the enter screen, USER (admin) and PASSWORD (password) but the password does not work?
Second problem, he has a computer up stairs which has a printer (hp3600) connected to it and he uses a laptop down stairs, which he says he can use to print using the printer upstairs. He has bought a wireless printer HP photosmart C7200, which he wants to keep down stairs. The setup instructions from HP says go to the network setup wizard, the printer will find networks, it finds everyone in the street including his AOL router. However, should it be making a connection to his home network not directly to his router??
Any help would be very much appreciated.
usually it admin & password
try admin admin
usually aol have the user pass typed on the router including the ip address, again usually.....
the first printer is it the laser model ?.
you should be able to prit a network page even with out it being connected then log in change the seting ie ip/subnet/gateway to what you need...
