Problem transfering PS3 saves.
27 Sep 2005
Burbage, Hinckley
I have sold my Jap PS3 and got a UK one instead. I copied most of my game saves over to my pen drive but for some reason theres a couple which wont copy. The only one im bothered about is The Godfather as I have got quite far, but when I try and copy the save it says not allowed...!!!
Anyone know if there is anything I'm doing wrong or is there another way to transfer this over to my new console?
I seem to remember that you have to either copy the whole folder full of the saves or each save individually. Not sure, Ill check a minute what i did with mine!
Josh
if you delete some of the game data ie RFOM install , oblivion install etc and a few others can you do a system back up to your pendrive? When i changed my HD to 160GB one I used an external USB drive to back up all the data, I forgot to delete the game info and it was about 11GB! So maybe deleting this and some of the movies etc you downloaded will work?
