Problem with 1080i resolution
20 Jun 2009
Hi guys,
Having a problem trying to put my monitor(s) into 1080i, The option appeared after purchasing my second monitor and plugging it today, However, when I try and set the resolution the screens are just flickering?
I am trying to do this through the nvidia control panel and the 1080i option is under HD, SD.
I have two Dell ultrasharp u2311h's running both with DVI cables from a nvidia GTX 275.
Any advice appreciated!
Why are you trying to use 1080i and not 1080p :confused:
Can you not this set the res as normal to 1920x1080@60hz ??
That is what the resolution is set at currently "native" 1920 x 1080 and no problems, I was just under the impression with the option for HD that the 1080i would be better quality? There isnt a option for 1020p.
Thanks.
The HD & SD options are for when you connect to a normal TV (LCD/plasma)
Thanks.
Using the 1920x1080@60hz normal option is far better then 1080i ;)
