Problem with 7800GTX
24 May 2004
Manchester
Hello
Got my GTX setup last night and it runs fine so i decided too install Rivatuner and push it a bit further. I upped the core from 475 too 490 and did a few benchmarks no problem. I then check the hardware monitoring tools in Rivatuner and at stock 475 core it reports the core at 510??
today i used the detetc optimal settings in coolbits and it detected 515 core so i started too benchmark which gave me artifracts so i jumped out and check Rivatuner monitor which reported the clock at 551!
Is this rivatuner messed up or is my core actually higher than it says? I am confused :rolleyes:
XFX 7800GTX Gamers edition
thanks in advance
bAz^uk said:
Hello
thanks in advance
Nope this is quite normal, my XFX GTX 256Mb used to do similar - apparently when running 3D apps it ups the core speed by about 25Mhz for some reason.
Someone else explained why a while back.
so although both the nvidia control panel and atitool report a clock speed of 490, it's actually what rivatuner reports, and is at 529 ?
Nvidia control panel and riva tuner actually say 475 in the core settings but in the real time monitoring tool in rivatuner it says core = 529 while in 3d applications. Should i be clocking this card down? Not sure whats safe for these GTXs. :rolleyes:
bAz^uk said:
Ok so when i am clocking i obviously need too take this jump in core speed into consideration, very strange :rolleyes:
Strange it is - but, I would say you have to change the way you overclock these cards, same principles apply really.
Must admit I've not checked to see if the 512mb version does the same..
But refitting my 256Mb version to an X2 rig this weekend :)
guys, the GTX has 3 diff clocks, while the shader and ROP run at says A Mhz, the Geometric runs at A + 40 Mhz (or 50 on some card). thats the way its run, perfectly normal :D
