problem with 82579V LAN
Permabanned
6 Feb 2010
Barnsley
Ever two or three boots my lan or drivers are not found and i have to reboot a few times to get it working, i even have to reinstall the drivers.
i have googled the problem and it down to cold booting?????
do any of you know of a fix or do i just buy a cheap pcie lan card
system in sig
If you refresh the Device manager it can change (right click top of tree and "scan for hardware changes"), that fix is a Firmware not driver, advise you install latest driver afterwards.
When i do what the file tell me to do i get this.
Also i still get the problem after boot
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\system32>82579VSKUW64e -nosilent
LVDASKU version 1.2.2
Tool to update Lewisville NVM ASKU
Copyright (C) 2012 Intel Corporation
Loading driver...
Scanning...
# Ven Dev SVen SDev Rev ST Device
1. 8086 1503 1462 7751 4 -- Intel(R) 82579V Gigabit Network Connection
U = needs updating
S = shared NVM; no update needed
* = update already performed
- = no update possible
No update required.
I got that the 1st time but cannot remember what I did to get it to run but it may be your already up to date and you have another issue.
If you are not getting the NIC changing names to that other model above then its not the same issue sorry.
I think I read the peeps input on the Intel site for this issue as it was a long time before it was fixed.
