- 14 Oct 2007
- Manchester
I helped my friend build a new computer a few months ago which he was going to use to run ProTools on (he was starting a course at Staffordshire Uni, as it happens). Anyway he got a pretty decent setup, listed below (if my memory serves me right):
Intel Core i7 920 CPU
Noctua Dual Fan CPU Cooler
Gigabyte EX58 UD5 Mobo
Coolermaster Cosmos RC1000 Case
4 Gigs of Corsair DDR3 Memory
Coolermaster Silent Pro 500W PSU
+ The usual Optical Drive, Two 1Tb drives for data and stuff, and a 150Gb Velociraptor for the OS.
As you might be able to tell, he wanted the rig to be pretty silent as he was going to use it to record instruments and vocals. A few days ago, he came to turn it on and nothing happened, as in nothing at all. No signs or life or anything. The night before it was fine and it didn't show any signs of bad things happening.
To try and diagnose the problem, he plugged in the PSU from another computer he had running (A Hiper 550W, I believe) and the computer turned on fine, which led him to believe it was the PSU at fault. He'd already tried a different power lead as well with no joy.
Today we drove to a local computer shop, RMA'd what we thought was the faulty PSU and got a new one, identical to the faulty one (the shop wouldn't allow him to have a different one, but nvm). As he was plugging the new PSU in now, the same thing's happening, except that the mobo does show signs of life in that when the large 24pin mobo cable is plugged in, the lights on the mobo light up for a short time before going off again. But as before, the power switch does not turn everything on as it should.
He then tried the new Coolermaster PSU in the computer which had the Hiper PSU in it and it turned on fine, so to temporarily sort the problem, he's swapped the two PSUs around, though ideally it'd be best if the silent Coolermaster one was back in the Comp that was running Pro Tools. Does anyone have any idea why the Gigabyte mobo doesn't seem to like having the Coolermaster PSU plugged into it? I find it odd that it won't work in this mobo, but it will work in an older one (implementing a P35 chipset), and that Hiper PSU will work with the Gigabyte mobo.
Cheers
Cheers
