- 14 Oct 2005
- Pembrokeshire
Hey all
Got my new large computer desk, and set up my C370 and Q1's around it. The Q1's are currently sitting at either end of the desk, about 10cm from the wall, slightly toed inwards.
The NAD is set to Tone Defeat, and is hooked up to my PC soundcard, a HDA X-Plosion. Playing music, it does sound good, but the bass just isn't there, when sitting in my normal listening position. If I move to the back of the room, there is some really nice sounding bass. Can also be heard if I lean forward so that my ears are sitting right between the two speakers, rather than in front of them, like normal.
I can get a better bass response if I disable tone defeat and turn up the bass control, but it still doesn't sound as authoritative as when I move into one of the two above locations. I'd guess it also puts more load on the amplifier than necessary.
Is there anything I can do to improve the bass response with my current speakers, changing their location and what not. I did plan to mount them on the wall, will this improve their bass response?
As these Q1's are going back to where they came from (long story), I am free to change to a different set of speakers which may be better suited in the environment they are in. As this room is small (8ft6" square roughly), and I sit relatively close to the speakers, perhaps speakers designed for near field use would be better? Or do I need a sub? Though if the problem can be sorted without changing speakers that'd be nice
Thanks for any help you can give!
