Problem with brakes.....and dealership
29 Nov 2007
UK
I have a 350z which I took for a p2 service yesterday. After waiting around for 2.5hrs I went to see what was up - "sorry sir, we haven't started yet!!!"
After giving them some stick and getting £100 refund and valet I was finally able to go home. This is when I discovered a problem. (I didn't turn around cos I was just glad to be on my way home after 4 hours and thought I'd see if the internet-super-heros knew a quick fix first)
The problem is with the brakes. They are now very soggy, with about 75% travel before anything starts stopping. If I pump them a couple of time they're fine on the 3rd pump, but go back to soggy in seconds.
Could there be air in the system somewhere? Would this have been caused by crap mechanics? And is there a way I can quickly fix it before driving another 50miles to and from the dealership?
Thanks
yes they did, hence why I think they could have messed it up. they prob did it in a hurry as I was having a benny.
Yeh sounds like there's air in the system, take it back for them to bleed it properly.
Might be worth just checking there is actually enough fluid in it yourself though
Air in the system.
Would avoid driving the car as its not exactly safe/ideal and make sure they dont fob you off.
