Problem with cooler need help pls
1 Mar 2019
I recently just put together my pc and I have installed everything but there is a problem with the cooler (kraken x72) because on my motherboard (maximus hero xi) there is not enough 9 pin usb plugs and I’ve tried to use a splitter but now the cooler just isn’t working. If anyone could help that would be awesome
Does the cooler require USB or can it be left unconnected and run at full speed? I assume it connects directly to the PSU as well?
You can get cables that only use one row of the USB header, allowing 2 devices per header. If you have two devices using internal headers this may be a good solution.
The cooler has to be plugged in and there are only wires on one side of the plug but I’ve tried to plug it into other things and the first time I booted up my pc it worked but when I tried after that it just stopped working
What splitter are you using. Phanteks make a to notch hub that may help. The Corsair Commander Pro has a USB PORT TOO.
I am using a ****** one bc I couldn’t find any other one but if you have any suggestions that that would be really helpful
