Problem with core 0
3 Mar 2009
Hello
When i run OCCT after about 3 minutes, it stops and says that core 0 has gone above the threshold.
It does the same if i try at Stock and when i overclock. I have an Asus P9X79 PRO Intel X79 with a 3820k i7 with 16bg of kingston hyper x I use the h100i CPU cooler.
Not sure if it matters but when i play games i don't have any issues so i am a bit confused.
Any ideas please :)
Stu
It is saying 132, but when i use hardware monitor it doesn't go above 51 at stock, that's when i use intel burn test.
132 :o what are you clocking it to?
132 is at stock, but when i run hardware monitor it doesn't show that temp.
Could it be reading the temps incorrectly, because i just ran occt again with hardware monitor next to it. The temps got to 50 but in OCCT it spiked up to 154 and stopped but HWM looked normal.
