Problem with cs 1.6 and 32 inch lcd tv
26 May 2006
Edinburgh
Just setup my old PC to my 32inch Sony Bravia.
The graphics card is a Inno3D Geforce 7800 GS 256mb. When I load up 1.6 the maxium res I can select on normal mode is 1024 x 768 which runs no problem. When I select widescreen option I can put the res up to 1280 x 720 but the screen goes black with the monitor saying: unsupported pc output. Even if I try and select this resolution for the desktop I get the same error and the screen goes back.
Any ideas ?
How are you connected to the Tv vga , dvi ?
you need to go into nvidia control panel and try to set up a custom resolution preferably the same as your tvs max output i managed this on my tv
1366x768 is now selectable in some games and windows i have a 7900gs via a dvi to hdmi cable
