Problem with Dreamweaver and rolloverbuttons
Zaf
Zaf
16 Jan 2003
Derbyshire
Hey guys for some strange reason I cant get rollover images to work in dreamweaver this is the code i'm useing
Code:
<img src="images/listen.gif" alt="" name="listen" width="81" height="68" border="0" id="listen" onmouseover="MM_swapImage('listen','','images/listen_rollover.gif',1)" onmouseout="MM_swapImgRestore()" /></td>
where am I going wrong? :confused:
roll over function missing from page (MM_swapImage) ?
should be about 5 billion lines of code generated by dreamweaver near the top of the page to swap those 2 images over
I have this
Code:
<script type="text/JavaScript">
function MM_swapImgRestore() { //v3.0
  var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.01
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
  if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
  var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
   if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
I'm sure i'm missing somthing dead simple just cant put my finger on it
just tried your code and it works fine here
does the image exist ?
whats the file size and is it being preloaded ?
other than that no idea.. :(
