- 10 Mar 2012
Hey guys I need some serious advice about my system as I have a bad feeling it's burnt out due to a problem with my new EK Rad that I just bought.
I installed the Rad with no problems and used the screws provided for attaching the fans. After filling the res and turning on the system, it sparked at me and just refused to turn on. I inspected the case and realised that all the coolant had drained from the Res and was coming from the bottom of the new rad. I took it out the case and realised that the coolant had leaked onto the connector of my bottom fan, bitfenix spectre pro, which may explain the sparking.
On closer inspection of the Rad I noticed there was small traces of coolant coming from 2 of the screw holes where I had installed the fans. I have contacted ek and just waiting for a response. In the mean time I need some advice on what I can do about my system after it now won't even turn on.
I hope someone can give me some advice as I have put a lot of money into this system and just hope it hasn't all just gone to waste. Thanks guys
