Problem with EK Multi Port Top
22 Nov 2015
Wales
So it seems the inlet on the top of my reservoir is leaking after leak testing (perfect timing aye ;)), but could somebody please confirm if I need to use an extender in order to use the top ports, and if so, which one? Cheers guys :D #FloodyDisaster
Hi,
Yes you need to use extenders there since they are recessed ports.
You usually got a couple of these with your reservoir but if you need more, this is the one you need : EK-Extender G1/4 - Nickel
I see that you use black fittings. Unfortunately these little extenders are only nickel. If you really want black, you could use this kind of entender : EK-Extender G1/4 Socket - Black
It's a bit wider than normal but it's black ;)
Awesome, cheers Luc. Unfortunately I didn't receive any extenders with the reservoir, so I'll get one of the black ones you mentioned above and hopefully sort it :)
