Problem with Excel file size - help needed!
27 Sep 2005
Burbage, Hinckley
I have two tables of data, one 8MB the other is 4MB. Anyway, I went through the two tables and sorted the data into sub categories (months) and then combined all the data from the two into one document.
I then separated a quarters worth of data and emailed it to a colleague, it was about 3MB in size. This was 3 months ago.
I went to do the same yesterday, giving the next quarters data, but the file size is now 30MB and yet there are a similar amount of records to the first batch - I cant figure out what I'm doing differently!
HELP!!!!!
Are you using xls or xlsx?
Xlsx tend to be smaller..
Also, you can compress them really well with zip or 7z.
Use 7 zip and make a zip file on ultra. Windows can open them with out needing 7 zip installed
has someone filled a column or row all the way to the end, (ie row 65000 or column zzzzz or what ever)
when you open the sheet you can easily tell - look at both of the scroll bars that allow you to go up/down and left/right if the bar that you drag to scroo is small then in that access someone has filled (maybe a value so you can see it maybe a formula) all the way to the end...
Tried saving as both, hardly makes any difference. Also tried zipping it and while it's a lot small it's still far too big to email. About 13MB
Have you left pivot tables in it? They bump up file size considerably.
How do I check and clear pivot tables?
No, I have checked already and the data ends where it should.
forgot to add formatting filled all the way will also do it
Is there any way I can clear all formatting easily?
