- 29 May 2020
Decided to make a dedicated post to this specific issue I’m having with my heatsink & fans …
As I wanted a decent air cooler, i went with the impressive ZALMAN CNPS20X . My mobo is the Lian Li 011D Dynamic XL, because it was touted as being very spacious.
Well, turns out there’s only like 3-4 mm clearance left between the bolts running through the cooler to the side glass panel and i'm running into a problem with the second Zalman included 140 mm fan that sits on top of my RAM. My RAM is pretty high with its integrated heat sinks (GSKIL F4-3200C14D-32GTZSK) and this makes the fan pop up like a big cm over the heat sink, bumping into the glass panel...
So I’m pondering on what would be the best solution ?
https://imgshare.io/image/N2zGWn
https://imgshare.io/image/N2zQw9
- Reposition the RAM sticks underneath the heat sink. That's a possibility. That way the fan goes nicely at the side of the heat sink and all is ok. Only problem i have with that is that's not the recommended RAM placement of the mobo manufacturer (ROG CROSSHAIR VIII HERO (WI-FI)), recommending a B2A2 placement for two memory sticks. It would be a B1B2 config then. Would this create performance hits? I guess the B2A2 allows for dual channel memory ?
- Replace the Zalman fan(s) with 120mm ones Other possibility would be to replace either just the troublesome fan (or both) with 2 BEQUIET! SILENT WINGS3 120mm high-speed PWM fans (2200 rpm) which i have laying around anyway. That way the fan can sit on top of the RAM sticks without surpassing too much the heat sink. Only problem here is how to fix it some way to the heat sink so they don't fall off. The Zalmans come with integrated clips that clip the fan to the heat sink. I could run some wire thru the heat sink attaching the fans, but that's kinda last option solution. Any way to have some standard way to attach these 120mm fans ?
- Anything else you can come up with ...
