After my mate told me his computer was knackered I went down to have a look at it.
I turned it on, got into safemode then once restarting It wouldnt get anywhere near posting. So I went into bios and set everything on optimized defaults incase anything was messed up. before i could even exit bios it turned itself off.
so i tried again.. lasted a short time then turned off again..
I left it for 10 minutes incase it was overheating or somethign. booted it up and it got to the point where it would start running windows, then blue screened and shut down.
Gives me the impression the PSU or the Memory is buggered.
I dont fix pcs often so im not 100% , but that seems to be the likely problems?
its got a cheap crap PSU in it which has probably just burned out
