Problem with games.
30 Jul 2004
East Sussex, UK
Hi Guys,
I'm having some problems with two games.
NFS Carbon and GTA SA.
When I start either game, all I see is a lot of squares/glitches in game menu ects. I am running Windows Vista Ultimate and an Ati X1950Pro. With 2GB of memory.
I was using CATs 7.6, which worked fine, however when I went to 7.7's I had the problem, but other games ran okay. Then I uninstalled them and installed 7.8's, still same issue with two games..
They used to work..
Any ideas guys?
Many thanks!!
I'd clean the system using aticleaner ( or whatever its called) tool first to make sure all traces of the 7.7 drivers were gone. It sounds like when you try to reinstall the 7.6 drivers the system isnt replacing the card drivers with a previous version.
