Problem with GTX 260?
30 Jan 2007
PA, USA (Orig UK)
I've just sold a GTX 260 on the member's market, and whilst it was fully working on my system, even in SLI on a Corsair HX520W, it doesn't appear to work correctly on the buyer's system. This is a replacement for the 260 that just went skyward recently in his machine. He's running an FSP 500w which has dual rails (18a per rail), so if both rails are used should be enough for the card. Bear in mind he was running an MSI 260 recently, but that may have been the 55nm version, whilst the one I just sold to him was a 260 216 65nm version.
He's getting BSOD when booting up windows (error is something like Attempt to reset the display driver and recover from timeout). If he goes in under VGA mode all seems to be ok, but when he installs drivers and reboots, it BSOD's again.
We'd both rather just get the card working, and he's order a molex connector to try and force it to the 2nd rail (If it isn't using two already on the FSP??).
Been through a few things already, except a reinstall (Not sure whether that's an option for the buyer (he's a member on here however)).
It's possible that somewhere between here and there something went wrong but I know it arrived at my place, and was fully working.
Advice?
I ran two 260's in SLI on my corsair HX520w, but bear in mind that it is effectively a single rail unit. The FSP 500w Bluestream (dual rail) he has seems to get good reviews, I'm assuming at this point it isn't the PSU, but prepared to be wrong.
Just seems unfortunate that the card would die in transit as such. I'm assuming that as it gets in windows in VGA mode, it's something else screwing things up? (of course, the driver could enable things that are wrong/damaged or drawing too much power. Hard to say without a reinstall, but I don't think he's able to do that).
when i first upgraded from 9600gt to the gtx260, i was using a 580w psu. and it kept just powering off at random times when i was loading up higher spec games, im assuming because of the extra usage in power? maybe there isnt enough amps on each rail to provide sufficient power?
I did suggest it might be the PSU, but I really don't want to say that he should buy a new PSU in the hope that it's the problem. I think that with it being twin rails it could be the issue but to be honest it could be any number of things. Some people are unable to reinstall windows either and I respect that, not everyone is an enthuthiast. The gent did order a molex to PCI-E adaptor to try and force the 2nd rail just in case it was trying to run of one rail, but no luck.
For the moment I have offered a refund as I sold my other card so can no longer send him that. Obviously I hope the card does work when I get it back though.
Bah.. life lol.
Anyone got any other suggestions that it might be before I pay for postage back etc?
