- 11 Aug 2003
- Taunton, Somerset
Hi all
I have an anoying problem that some here may have come across and been able to fix
I have moved my pair of GTX260s to a new rig
AMD 955BE
4GB DDR2 1000
MSI KA92 Platinum
2 x 250GB HDD RAID1
DVDRW
Corsair 850HX
Sunbeam contact cooler
Windows XP SP3
One GTX is connected to a monitor the other is connected to the television via s-video cable (TV not on all the time)
Now in the old rig this problem only occurred once or twice, a reboot sorted it out and I wouldn't see it again for months however it seems to be happening all the time now
The problem is that one of the cards seems to clock itself back when it feels like it whether it be in the middle of a work unit or not! One card is a Sparkle the other is a Point of View and they are both clocked to 576/1500/999 using EVGA's precision tool - I found that Riva tuner would only clock one card on start up and you would have to manually clock the other card every time the PC was rebooted.
If you allow the card to go idle then you can see the core and the shaders clock them selves back and then when under load clock themselves back up - normal energy saving behaviour but surely this shouldn't happen when the card is crunching a unit.
Anyone got any ideas?
I had thought I might use NiBiTor to edit the BIOS to make the overclocks a permanent change and I think I can also stop the cards clocking themselves back if I make the right changes, however I don't really want to use NiBiTor because, knowing my luck, I'll kill the cards
**Edit** sorry meant to say this is a Folding problem
AMD 955BE
4GB DDR2 1000
MSI KA92 Platinum
2 x 250GB HDD RAID1
DVDRW
Corsair 850HX
Windows XP SP3
