Problem with Haier fridge/freezer.
1 Sep 2011
Peterborough
We have the above fridge/freezer, but as ove this morning it doesn't appear to be cooling as good as it should be.
We have pressed the 'quick freeze' button but the temperature doesn't appear to be coming down to as it normally would be.
The food in the fridge appears to be OK, but we normally have it cooler.
I'm not going to pretend to know what i'm on about but even pressing the buttons to turn the temperature down are not responsive.
Is it just on it's final legs?.
It's this one, if that helps...http://www.fisherselectrical.co.uk/haier-cfe633s-frost-free-fridgefreezer-384-p.asp
Can you hear the pump running to keep the fridge cold? Or is it silent, and simply has the residual 'cold' from the food keeping cool.
Unplug it, leave it uplugged for 30 mins, plug back in again. If the pump doesn't start immediately, give the side of it a good firm open-handed slap.
Works for my fridge :)
