Problem with hardware
3 Nov 2009
*OVERCLOCKED* Intel Core i5 750 2.66Ghz @ 4.00GHz / Gigabyte GA-P55-UD5 Intel P55 Motherboard / Corsair XMS3 4GB (2x2GB) PC3-12800C9 1600MHz DDR3 Bundle £417.38 1 £417.38
Sapphire ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card £193.03 1 £193.03
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £68.69 1 £68.69
SMG F3 1TB 3.5
HD103SJ SMG F3 1TB 3.5" SATA2 7200RPM 32MB € 73,45
ANTEC THREE-HUNDRED CASE NO PSU BLACK
0761345-08300-3 ANTEC THREE-HUNDRED CASE NO PSU BLACK € 55,90
OPTI 5240S DL DVDRW 24X BLACK SATA
AD-5240S-0B OPTI 5240S DL DVDRW 24X BLACK SATA € 22,90
9H.L3ALB.QBE-1 BENQ G2420HD 24" 5MS/FULL HD/HDMI/DVI € 179,00
I have that kind of computer.
I am having stability issues as well as:
"Sometimes randomly after few hours of running when the system is at desktop and has no big computing to do the screeen goes black for few secounds and the computer informs me that the driver has recovered from somekind of error.
The windows does not let me fix it from windows but one time it gave this additional information:
Source
Windows
Summary
Video hardware error
Date
‎13.‎11.‎2009 11:43
Status
Solution available
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1035
Extra information about the problem
BCCode: 117
BCP1: FFFFFA800413A320
BCP2: FFFFF880048D46A0
BCP3: 0000000000000000
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Bucket ID: X64_0x117_DxgKdxFailed_IMAGE_atikmdag.sys
Server information: dcb30f54-7040-4969-8394-f8f8541f1602
Can you specify what is going on? And Could I have rechieved faulty parts?
I have newest drivers for saphire card and I did install everything that came with the motherboard but was that actually mistake since I run win 7?
The problem might be about this:
http://forums.amd.com/game/messageview.cfm?catid=260&threadid=104677&enterthread=y
But I can't really pursue this since I can't for example change bios without possibly harming my overclock?"
I am running win 7 64bit.
btw. What kind of 3d vantage scores should I get?
There are umpteen possible causes.In the first instance I would drop the overclock and return the CPU to stock. If you are concerned about your overclock, just make note of the bios settings.
I kinda figured that....where should I start. I want to go with this setup if it is workable. I dont like to return fully working equipment because of my own fukups....
I have no experieince of that board, but in short, look for the appropriate area to FSB, multiplier, CPU voltage etc.... and roughly speaking anything set to manual, flick it back to auto. (After making a note of course)
