Hello, im having a bit of a problem with my gfx card temps and cpu temps, i know the reason but im not sure what to do as i cant move the Thermalright cooler to another position. Here is a pick of the inside of my comp(i know its messy cos its getting stripped out tomoz). The Thermalright vga heatsink is on my HD2900 Pro, the heatsink above it is cooled by a 80mm Noctau fan however it blows the hot air right into my AC Pro7, if i mount the Thermalright heatsink the other way the hot air will need to be blown down which makes it harder as convection of air makes it want to rise, it will also be harder to get the air out as it would be blowing it directly onto the metal panel that covers the Corsair HX620. Can anyone think of a way I could mount the Thermalright vga heatsink so that it gets cooled properly, without heating up my AC pro7?
(its an antec p180 case btw)
Cheers Dom
Cheers Dom
