Hi all,
I have a problem with the high level brake light on my yaris. The normal two brake lights work but not the top high level one.
Now I checked the fuse, and that's ok, not blown, as if it was the normal two brake lights wouldn't work.
So then I bought another unit thinking it might be the unit fault, but that doesn't seem to work either.
Now I'm guessing it might be the connector, or there is a break in the connection somewhere. I tried my best to follow the connection round and I think it connects to the right brake light.
What next steps should I take?
Thanks in advance.
Thanks in advance.
. It's a bit annoying as I do like a car to be perfect.
