Problem with Javascript / Flaswh player in IE
27 May 2003
All websites with Javascripts seem to work fine apart from Youtube which most of the time says javascript is turned off or I need to update Macromedia Flashplayer. It works sometimes though.
It is enabled in IE6 and I have updated flashplayer.
Anyone know what the fudge is going on?
Ta!
Had the same problem myself,by anychance do you have Regseeker installed? When i was installing Flashplayer everything was fine & would work fine for days then i would get the "You have Javascript disabled error".It turned out to be Regseeker removing reg entrys for Flashplayer when i would do a cleanup.Added these flashplayer entries to the ignore list and all is fine now.Took my ages to work out what the problem was.
