- 25 Mar 2015
Hi all, I got a weird problem with my keyboard that’s been driving me mental. What happens is that my keyboard left portion stops responding. Tapping any of the `123456 and wasd keys instead causes a spamming of `123456 and other keys, non stop. So when I press perhaps W once, I get all those letters being spammed.
When I open word or notepad to see whats going on, I press one of these buttons on the left side of the keyboard and it just Spams non stop without any of my input. Sometimes I get a message that the CTRL button is being held down which is not the case.
Restarting the computer once does not solve the issue, nor does unplugging the keyboard as after a restart or replugging, if I attempt to type anything, I get that random gibberish again. The only way to ‘solve’ it is to turn my computer off and leave it like that for an hour then turn it back on again.
So far it only happens once or twice a month randomly for the past 3-4 months and so far it only happens when I played two games, Supreme Commander Forged Alliance and Star Wars The Old Republic. When it happens though its exasperating like anything as I have to apologise to my friends/teammates and just pull out of the raid/battle. After that I can’t do anything for like an hour before I turn my computer back on.
Now I only built this system late last year and apart from this stupid problem, everything works fine. Every bit of hardware has the latest drivers/firmware etc.
Windows 7 Ultimate 64-bit
1000W Cooler Master
Asus P8Z77 WS
Intel I5 3570k
16GB Corsair DDR3 Vengeance
Asus GTX 760
512GB OCZ Vertex 4 M 2.5" SSD
WD Caviar Greens and a Black for storage
Logitech G430 for sound, or I plug speakers to the mobo.
Logitech G400s for the mouse
Keyboard is a Armaggeddon Stealth Raptor MKA-7 Mechanical Keyboard or Razer Blackwidow Ultimate Stealth 2014.
Now, I was given the Armageddon keyboard as a gift from a friend last year as he always knew I wanted a mechanical keyboard and it worked fine for months until early this year, when the symptoms above started happening. I then bought the Razer keyboard last month because I thought the Arma keyboard might be acting up. However, the same problem persisted with the Razer one also. Before I started using these mechanical keyboards, I was using a bog standard ps/2 keyboard that had no problems.
Now I’ve been doing my homework and was looking at what might be the problem. In terms of drivers, it seemed that the Logitech Gaming Software that’s used by my headset and mouse, generates a virtual keyboard HID that cannot be disabled under device managers. This might cause conflict with an actual keyboard that I’m using though I’m not sure this might be the cause.
The Arma keyboard has its drivers and the Razer one has Razer Synapse but given that the problem it only happens once in a blue moon, I don’t think they are causing the problem, if they are, I would be getting keyboard going crazy everyday.
There is the possibility that the Asus USB ports might be the problem but in normal usage, if I plug anything in them, they work fine and I have no way of checking if they have a problem. I used an old usb mouse to plug into each port as a test to see if they work and all of them can pick up the mouse and it works.
The thing that gets me is I cannot ‘reliably’ replicate the problem else I would be able to suss out the problem myself. It has so far only happened 4 times, twice in SWTOR and twice in Sup Com (those are the two games I spend most of my free time on). Like I stated before it seems to randomly happen once every few weeks.
I even thought it might be a windows problem as windows does have history with weirdness happening, so I formatted my SSD and reinstalled a fresh windows 7 on top, updated it, the whole gamut etc. I did not transfer any drivers/settings or anything from my old computer except for documents etc. The problem reoccurred 2 nights ago, so its not Windows 7 fault.
I’m hoping one of you forumites might have encountered similar issue to this in the past, as all my google-fu has turned out solutions for Laptop keyboards or damaged ones, not for ‘working’ desktop keyboards. Thanks for any help, I’m truly exasperated here.
Attaching a DX Diag also
1000W Cooler Master
Asus P8Z77 WS
Intel I5 3570k
Asus GTX 760
System Information
Time of this report: 3/25/2015, 16:35:05
Machine name: PLANESWALKER-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150202-1526)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 03/13/13 17:28:47 Ver: 35.05
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16326MB RAM
Page File: 4057MB used, 28591MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 760
Manufacturer: NVIDIA
Chip type: GeForce GTX 760
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_1187&SUBSYS_847A1043&REV_A1
Display Memory: 4038 MB
Dedicated Memory: 1990 MB
Shared Memory: 2048 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: ASUS VS239
Monitor Id: ACI23D2
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: DVI
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4752 (English)
Driver Version: 9.18.13.4752
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 2/5/2015 21:01:44, 17253848 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71E3E-52C7-11CF-6361-77A41CC2C435}
Vendor ID: 0x10DE
Device ID: 0x1187
SubSys ID: 0x847A1043
Revision ID: 0x00A1
Driver Strong Name: oem3.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section035:9.18.13.4752
ci\ven_10de&dev_1187
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_104384D8&REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6657 (English)
WHQL Logo'd: n/a
Date and Size: 6/12/2012 17:10:44, 4060560 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04D9, 0xA096
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: usb\root_hub20
| Service: usbhub
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: usb\class_09
| | Service: usbhub
| +-+ Generic USB Hub
| | | Vendor/Product ID: 0x058F, 0x6254
| | | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Vendor/Product ID: 0x046D, 0xC232
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Logitech Optical Gaming Mouse G400s
| Vendor/Product ID: 0x046D, 0xC24C
| Matching Device ID: hid\vid_046d&pid_c24c&mi_00
| Lower Filters: LGSHidFilt
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 102.8 GB
Total Space: 488.3 GB
File System: NTFS
Model: OCZ-VERTEX4 ATA Device
Drive: D:
Free Space: 4888.0 GB
Total Space: 5723.0 GB
File System: NTFS
Model: WDC WD60EZRX-00MVLB1 ATA Device
Drive: E:
Free Space: 175.1 GB
Total Space: 1907.7 GB
File System: NTFS
Model: WDC WD2002FAEX-007BA0 ATA Device
Drive: F:
Free Space: 34.4 GB
File System: NTFS
Model: WDC WD20EARX-00PASB0 ATA Device
Drive: G:
Free Space: 86.7 GB
File System: NTFS
Drive: H:
Model: HL-DT-ST DVDRAM GH22NS70 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), , 0 bytes
System Devices
Name: NVIDIA GeForce GTX 760
Device ID: PCI\VEN_10DE&DEV_1187&SUBSYS_847A1043&REV_A1\6&3671BECE&0&00400008
Driver: n/a
Name: Intel(R) Z77 Express Chipset LPC Controller - 1E44
Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_84CA1043&REV_04\3&11583659&0&F8
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 7 - 1E1C
Device ID: PCI\VEN_8086&DEV_1E1C&SUBSYS_84CA1043&REV_C4\3&11583659&0&E6
Driver: n/a
Name: Intel(R) 82574L Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_10D3&SUBSYS_83691043&REV_00\4&21A1C3AE&0&00E5
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_847A1043&REV_A1\6&3671BECE&0&01400008
Driver: n/a
Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_84CA1043&REV_04\3&11583659&0&B0
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 6 - 1E1A
Device ID: PCI\VEN_8086&DEV_1E1A&SUBSYS_84CA1043&REV_C4\3&11583659&0&E5
Driver: n/a
Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_84CA1043&REV_09\3&11583659&0&08
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10B5&DEV_8747&SUBSYS_874710B5&REV_BA\5&2728BA6D&0&800008
Driver: n/a
Name: Intel(R) USB 3.0 eXtensible Host Controller
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_84CA1043&REV_04\3&11583659&0&A0
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
Device ID: PCI\VEN_8086&DEV_1E18&SUBSYS_84CA1043&REV_C4\3&11583659&0&E4
Driver: n/a
Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor DRAM Controller - 0150
Device ID: PCI\VEN_8086&DEV_0150&SUBSYS_84CA1043&REV_09\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_10B5&DEV_8747&SUBSYS_874710B5&REV_BA\5&2728BA6D&0&400008
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_84CA1043&REV_04\3&11583659&0&D0
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 4 - 1E16
Device ID: PCI\VEN_8086&DEV_1E16&SUBSYS_84CA1043&REV_C4\3&11583659&0&E3
Driver: n/a
Name: Marvell 91xx SATA 6G Controller
Device ID: PCI\VEN_1B4B&DEV_9130&SUBSYS_84381043&REV_11\4&3927C719&0&00E7
Driver: n/a
Device ID: PCI\VEN_10B5&DEV_8747&SUBSYS_874710B5&REV_BA\4&BAB4994&0&0008
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_84CA1043&REV_04\3&11583659&0&E8
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 3 - 1E14
Device ID: PCI\VEN_8086&DEV_1E14&SUBSYS_84CA1043&REV_C4\3&11583659&0&E2
Driver: n/a
Name: ASMedia XHCI Controller
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&11EB9DBD&0&00E4
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_84CA1043&REV_04\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_84CA1043&REV_C4\3&11583659&0&E0
Driver: n/a
Name: Standard AHCI 1.0 Serial ATA Controller
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_84B71043&REV_01\4&D432303&0&00E2
Driver: n/a
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_84D81043&REV_04\3&11583659&0&D8
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller - 1E02
Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_84CA1043&REV_04\3&11583659&0&FA
Driver: n/a
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3403&SUBSYS_83841043&REV_01\4&2543D5D&0&00E3
Driver: n/a
Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 8 - 1E1E
Device ID: PCI\VEN_8086&DEV_1E1E&SUBSYS_84CA1043&REV_C4\3&11583659&0&E7
Driver: n/a
Name: Intel(R) 82574L Gigabit Network Connection #2
Device ID: PCI\VEN_8086&DEV_10D3&SUBSYS_83691043&REV_00\4&299066B9&0&00E6
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.18221
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.03.4533.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.03.4533.0000
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.03.4533.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.18741
LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.64.0000.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.18741
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.18741
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9200.17037
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
MACSReaderMP3 Filter,0x00200000,0,1,MACSReaderAVI.ax,1.00.2006.0804
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.18741
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
SelfMusicVideo Dump Filter,0x00200000,1,0,TG_Dump0708.DLL,8.01.2008.5200
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.18741
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.18741
Haali Media Splitter,0x00400000,0,1,splitter.ax,1.13.0138.0014
Haali Media Splitter (AR),0x003fffff,1,1,splitter.ax,1.13.0138.0014
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.18741
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.18741
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.18741
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.18741
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.18741
Haali Video Renderer,0x00200000,1,0,dxr.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.13.0138.0014
VSFilter,0x00200000,2,1,vsfilter.dll,1.07.0008.0061
VSFilter (auto-loading version),0x00800002,2,1,vsfilter.dll,1.07.0008.0061
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.18741
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.18741
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.13.0138.0014
NEDFilter4Samsung Filter,0x00200000,0,1,NEDFilter4Samsung.ax,8.01.0000.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.18741
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
DC-Bass Source,0x00400000,0,1,DCBassSourceMod.ax,1.05.0002.0000
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.03.4533.0000
LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.64.0000.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.18501
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.18501
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.18741
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.18741
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.18741
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.18741
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.18741
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.03.4533.0000
madVR,0x00200000,1,0,madVR.ax,0.87.0013.0000
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.18741
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.18741
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.18741
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.64.0000.0000
LAV Video Decoder,0xff800000,1,1,LAVVideo.ax,0.64.0000.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.13.0138.0014
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.18741
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.18741
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.03.4533.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.18741
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Lagarith Lossless Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
x264vfw - H.264/MPEG-4 AVC codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.18741
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.18741
AC-3 ACM Extensible,0x00200000,1,1,quartz.dll,6.06.7601.18741
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.18741
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.06.7601.18741
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.18741
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.18741
WDM Streaming Capture Devices:
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Realtek High Definiti,0x00200000,1,0,quartz.dll,6.06.7601.18741
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.18741
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18741
DirectSound: Realtek Digital Output(Optical) (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18741
DirectSound: Speakers (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.18741
Realtek Digital Output (Realtek,0x00200000,1,0,quartz.dll,6.06.7601.18741
Realtek Digital Output(Optical),0x00200000,1,0,quartz.dll,6.06.7601.18741
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
System Information
Memory: 16384MB RAM
DxDiag Notes
Display Devices
Monitor Id: ACI23D2
Output Type: DVI
DDI Version: 11
WHQL Logo'd: n/a
Vendor ID: 0x10DE
Device ID: 0x1187
Revision ID: 0x00A1
ci\ven_10de&dev_1187Rank Of Driver: 00E02001
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
USB Devices
+ USB Root Hub
| Service: usbhub
+-+ Generic USB Hub
| | Service: usbhub
| +-+ Generic USB Hub
| | | Service: usbhub
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: kbdhid
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Drive: C:
File System: NTFS
Drive: D:
File System: NTFS
Drive: E:
File System: NTFS
Drive: F:
Free Space: 34.4 GB
File System: NTFS
Drive: G:
Free Space: 86.7 GB
File System: NTFS
Drive: H:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
PBDA CP Filters:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
Quality Flags: 2576
Enabled:
Force throttling
Allow scaling
Enabled:
Force throttling
Allow batching
Force scaling
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
