problem with lan....
5 Jan 2005
Engerland :)
i have pc upstairs (windows 8)
hp micro server downstairs. (windows 7)
connected via ethernet to virgin super hub.
all connects - can transfer files between 2 no problem.
recently i cant connect via my nexus 7 or android phone via wifi. was using es file explorer to play films etc. if i search it finds the hp microserver ip address but just gives an error.
teamviewer works fine to access the hp server across wifi.
now i keep getting smb out of range etc etc... with file explorer
any ideas?
hmmm it seems to be working now after restarting the server. seems a bit hit and miss though. any reasons for this?
One of those "Have you tried turning it off and on again?" moments? :)
Maybe related to the HDDs being spun down and the time out period expiring in the app while waiting for a response?
had a look today. changed power settings on server.
went to connect via es file explorer....connection error.
hit teamviewer from nexus over wifi - connected no problem.
anybody know what i can try?
sounds to me file the app es file explore is timing out when trying to connect.
how long does it take before it fails?
you do need to check the event logs as mentioned above. that'll stop you blindly stumbling around in the dark..
EDIT:: we run a sonic FW with a vpn client and I'm forever having to change peoples outlook settings from server names to ip addresses the dns lookup seems to nearly always timeout.
ok i checked the logs i see this error in the system log. this happens each i connect through es file explorer.
Level Date and Time Source Event ID Task Category
Error 14/12/2012 23:22:00 srv 2017 None The server was unable to allocate from the system nonpaged pool because the server reached the configured limit for nonpaged pool allocations.
lol this mean anything to you guys?
Just stick 'The server was unable to allocate from the system nonpaged pool because the server reached the configured limit for nonpaged pool allocations' into Google and there are plenty of suggested fixes.
