Problem with laptop
19 Oct 2002
Liverpool
I have a friend's Sony Vaio laptop here, and it wont boot into windows XP. When booting I get the XP loading screen and then a blue screen saying unmountable_boot_volume.
I have tried booting in safe mode but that brings up the same screen. I have read around, and most places suggest using recovery console, or formatting. I tried this but I can't get the laptop to boot from the cd drive - there are no internal drives, just a dock with floppy/cd drive.
So does anyone have any ideas how to fix this?
Thanks in advance,
Rich.
Ok, finally managed to get a fresh install on the hard drive; I connected the lappy hdd to my desktop using an ide converter and put XP onto it. (Turns out the cd-rom on the dock is faulty).
Only problem is, when I replace the hdd back into the lappy, I get 'operating system not found', even though I could run it on my pc.
Any ideas?
Cheers,
Rich.
This is because you have installed the OS based on the hardware in your own PC , the laptop is completely different and the OS will not work when you swap it back into the laptop. Get a working CD-rom drive, set in the BIOS to boot from CD first and install it again.
