Problem with Lightroom presets
5 Mar 2006
Shropshire
Ok not sure if this is a known issue.
I have created a few presets which include a radial filter in them. Problem is the radial filter doesn't seem to be removed if I click on another preset which has no radial filter in it. So it gets stacked up. Is there any way around this?
Ok just answered myself -
I added a radial filter that does nothing to my other presets that didn't have one - that will remove the radial filter from other presets applied, but sounds a bit of a kludge. Any thoughts?
That is a feature of LR presets. Generally if you want to try a new preset then you should reset the image first.
Happens with most things, on purpose. E.g. A preset that changed the colour process or adds vignettign, if these are changed with the new preset then then the new prese twill I heritage the previous settings.
Makes sense DP, since I like trying out my set. A reset before apply option might have been nice.
It can be annoying when something you don't wont carried over is, at the same time it is nice when some settings are preserved (e.g. Lens corrections/color process/etc)
