- 22 Jul 2015
- Aberdeen
I am in the middle of a new build and planning on using Mayhems Pastel White + Mayhems dyes to match the build theme. I did some test mixing to achieve the desired color.
- Left glass bottle is Mayhems Pastel White + Emerald Green dye + Yellow Dye
- Right glass bottle is Mayhems Pastel White + Purple dye + Deep Red dye
When the fluid is left for a few hours, some segregation appears to take place, probably some solids floating on the top. This is happening in both the mixtures. It is quite worrying for me. In the past I have used Mayhem's Pastel White but without any dyes, which was ok. Can someone help with this? Will this mean that my blocks will clog up pretty quickly or is it something normal? Thanks
