Problem with MEI driver - can't change setting in bios
11 Dec 2005
Brighton
Hi guys,
I have a problem with one pc (Asus z87 pro, i5 4670k) and can't find a solution to it. The ME version reads N/A in bios and apparently I need to install the MEI driver but when I tried to I got the message the system is not supported.
I tried flashing the bios several times with older and the last bios and still ME version N/A which doesn't allow me overclock the system as the bios don't save my settings.
Running out of ideas :(
If that doesn't work I'd say you're at the point of resetting/reflashing the BIOS with the latest 2103. I've got a Z87 Pro here with a 4700K, and it does have a version number under ME in the BIOS, so there is definitely something on yours not working the way it should.
