Problem with msn (vista)
10 May 2004
Middlesex
Hey guys,
I'm having a problem with MSN on my Vista computer. For some reason it won't connect (comes up with an error message saying to check my firewall). I'm not using any software firewalls and the windows one is turned off.
On my other computers it works fine so I'm, don't think its a problem with my network connection.
I have had this problem on the same computer previously (it has worked fine for the last few months) and a reinstall of msn seemed to do the trick. It has not worked this time.
Any ideas?
Thanks a lot.
