Hello, a word of advice please.
I started to play “The Witcher 2” game (it’s a fantastic game), but I noticed a strange effect in the screen (not entire screen), seems to be an effect, but it scares me a bit.. I uploaded a video just to saw u what I mean.
I don’t see this kind of effect in other games and my graphic card is gtx480.
If its not a problem (and I wish not to be), which filter is doing that effect? I may wish to disable it.
When you see the video, try to make it full hd, so you can see what I mean better (change it to 1080p on YouTube). Try to see the skin of the characters and the shadows.. when they speak and move..
http://youtu.be/DvlkDCt-Q1s?hd=1
Notice: you cant see it well with 720p, please change it to 1080p when youtube loads..
extra information about game settings.
1920x1080 ress
texture downscaling --high
texture memory size mb ---medium
shadow quality -- high
number of shadowed lights -- high
LOD distanse --- near
Bloom --- enabled
Light shafts --- enabled
anti aliasing --- enabled
Blur effects -- enabled
Depth of Field (dof)---enabled
Vignette -- enabled
Wet surfaces rain effect -- enabled
SSAO -- enabled
Motion Blur -- enabled
Cinematic dof --- disabled
Depth of field - cutscenes enabled
Dangling Objects limit -- disabled
Ubersampling -- disabled
Vertical Sync -- enabled
Decals --- High spec
1920x1080 ress
Bloom --- enabled
Vignette -- enabled
SSAO -- enabled
