- 6 Mar 2013
OK so I just got a new system with the NZXT Kraken X61 installed (I did not build this computer myself and would not know how to do so) and for some reason the LED on the front of the device will not turn off when I shut my PC down. I have the CAM 1.2.3 software installed (this is the latest version) just for reference. I have tried googling the problem and the NZXT tech page says that this is normal and on another page I found a workaround that tells me to change a setting in the BIOS to allow it to turn off (something called s4/s5???) but that will also stop me from being able to charge devices when the computer is turned off (something which I do all the time).
So is anyone else having this problem and has anyone else managed to fix it without having to resort to switching the motherboard power off?
If this is a bug in the software, I'm surprised that NZXT do not seem to be doing anything about it (as this watercooler has been out for months and the language from NZXT make it seem like they do not see it as a problem).
I have also spoken to the shop that bought all the parts and built my computer and they have told me they can't refund the cooler as it's a software fault and not a problem with the cooler itself.
As a workaround of my own I have managed to turn the LED colour to black which has helped a bit but there is still a light on inside the pump when I turn the computer off although it is a lot duller then having a bright blue light keeping me awake all night. I do want the light to work when my PC is turned on though and this workaround stops that.
As a side reference, I have LED's in my fans and an LED lighting strip in my case that turn off just fine when I shut the PC down, this can't be some super difficult issue to resolve.
Thanks folks.
Thanks folks.
